17.5" Tires
Old Jul 12, 2025 | 07:27 PM
JohnNewb's Avatar
JohnNewb
17.5" Tires
Any F350 owners know what replacement tires will work? My 8-17.5 Firestone nylon tires are scary old and so hard I don't think I need air in them. The local tire shops can't find replacements. I found online 215-75r-17.5 listed as truck tires any position.. I swapped the rear end in the past and have 225 -85-16s in back. Front rims are tubeless dually rims with 6 lugs.
Old Jul 13, 2025 | 12:58 AM
MARC's Avatar
MARC
Tires
STA Super Traxion at stausaonline.com
Old Jul 13, 2025 | 08:55 AM
JohnNewb's Avatar
JohnNewb
I'll check them out, thanks
Old Jul 13, 2025 | 10:30 AM
MARC's Avatar
MARC
Tires
However they are a tad pricey
Old Jul 13, 2025 | 10:39 AM
swann79's Avatar
swann79
Last time I looked, which was a few months ago, the expensive bias plys are currently our only option. Nobody is making a radial at the moment. Eventually, somebody may fire up a run of them... at least I hope so.
Old Jul 13, 2025 | 11:29 AM
JohnNewb's Avatar
JohnNewb
Originally Posted by swann79
Last time I looked, which was a few months ago, the expensive bias plys are currently our only option. Nobody is making a radial at the moment. Eventually,I somebody may fire up a run of them... at least I hope so.
The ones I listed in my post are radial tires. From GigaTires they are around $105 each. Shipping costs about $120 for two. My concern was the size compared to what I have. 215-75R-17.5. I am going to measure the old tires. I've never ordered tires online.
Old Jul 13, 2025 | 01:16 PM
JohnNewb's Avatar
JohnNewb
So, tire experts, my old 8-17.5 tires measure 6" tread, 8" wide, just under 30" tall mounted. The 225-85R-16s are pretty close except tread width is 6.75". I can't find 85s anywhere, only 75s and most are 16 ply. They are listed as 30.6" diameter, 8.9" wide and for 6"-6.5" rims. I think there is enough room for them. I know they are cheap Chinese tires but this truck does not get on the road a lot.
Old Jul 13, 2025 | 01:54 PM
swann79's Avatar
swann79
Looks like they should work in theory... I saw a Winnebago post that successfully used them. Let us know how it goes if you decide to try them!
Old Jul 13, 2025 | 02:31 PM
JohnNewb's Avatar
JohnNewb
As long as they fit, they will work for me. I'm not concerned about ride quality.
Old Jul 25, 2025 | 03:14 PM
JohnNewb's Avatar
JohnNewb
Got them, they fit.
Old Jul 25, 2025 | 08:18 PM
swann79's Avatar
swann79
Excellent! Thanks for the update.
Old Jul 25, 2025 | 08:26 PM
JohnNewb's Avatar
JohnNewb
Here's a question for the wheel experts. I noticed the dually adapters bolt onto the drums with 8 bolts. Are these the same pattern as an 8 lug non dually rim?
Old Dec 9, 2025 | 09:36 PM
GB SISSON's Avatar
GB SISSON
If you are talking about the adapter on the front of an F350, it is not actually an adapter. The big flared bell hub is one piece. The 8 bolts you see, hold the drum onto the hub. These bolts are indeed same as 8 lug wheels and dually adapters. On my '59 f350, I cut off the bell and installed longer studs and bolted on dually adapters. Then swapped rear axle to a sterling 10 1/4". Now the truck is all 8 lug. 10 years now. Hope this helps.
Jim1521
Sep 23, 2023 02:44 PM
fordboy5894
29
Jun 17, 2021 09:30 PM
parkland
17
Jan 26, 2010 06:14 PM
Elynn_03
Jan 3, 2003 08:24 PM
logan_85
Apr 26, 2001 11:25 AM
