Sponsored by: Kumho
dually tire questions
Old Mar 6, 2001 | 08:42 PM
logan_85's Avatar
logan_85
I recently bought a '94 F-350 4x4 with tires on back that now look a lot like raceing slicks(front tires are near new, I wish I could say the same for all 4 rear tires). I have thought about simply buying 6 goodyear wrangler tires since I really like the look of the tread, and I would have 2 spare tires(the old front tires). My question is if the front and rear tires are on the same rim. The guy I got the truck from said the front tires are different, but they have hub-caps which make them look the same as the back. One of the stickers on the inside of the door says the rims(front and back) should be 16x6. All 6 tires are 235/75R16. Any quick and easy(without takeing off any tires yet) to find out if the rims are interchangeable?
Logan
Old Apr 25, 2001 | 05:50 PM
badf3504x4's Avatar
badf3504x4
i have an idea, try taking off the hubcap and look to see if the wheel size is 16x6 is should be stamped on the rim in the dish on the flat part. try that. good luck i think it should be the same i also have a 94 F-350 diesel 4x4 and i have been having trouble (maybe some one can help me with this) because the rims are 16x6 its hard to get bigger tires or custom dually wheels because all i have found are 16x6 and if you are concidering going bigger with more aggressive tires than i have found 34x9.5x16 which should fit but i am afraid of placing a 9.5 on a 6 inch wide rim. anyway hope i could help.
Old Apr 26, 2001 | 11:25 AM
lallen's Avatar
lallen
SC78f150
Jan 15, 2014 07:56 PM
pcskies
Apr 8, 2008 12:25 PM
logan_85
Offroad & 4x4
Mar 8, 2001 03:06 PM
