Rotating tires on DRW?
If I were to rotate them, would it be just left->right or do they need to be taken off the rims and all rotated? I don't have the equipment to do that, so I would have to take it to a tire shop to have it done. Should I do it? Is it worth it? If so, how often should I do it?
EDIT: PS, and another thing I do is when I replace tires, I find an all-season for the front that is as close to an actual rib design as possible rather than all-terrain since I am primarily a pavement pounder and use the all terrains on the rear. I have an off road vehicle for the fun stuff!
If you have steel rims, they SHOULD all be the same and you can use the old 'inside to outside, outside to front, front to inside' rotation.
It's still a good idea to do it, as it can give you information about whether something is starting to fail in your vehicle. If you do it yourself, it's also a good time to inspect your brakes/bearings/steering linkage, and make sure everything is good there. But if everything looks good you can usually put it off if needed.
Fronts yes, swap side to side before a wear pattern starts. Once a pattern starts it is likely there for the rest of the life of the tire, regarless of what one does.
typical rotation pattern is front to inners and outers to front.
As long as your steers are even and each pair (or side) is even and equal tread depth all is good.
When you have to replace a tire, buy at least a pair and replace the steers, then move whatever is better to the inners. Never do a single replacement or it'll jack up your rotation. Most people don't know that if a pair of rears aren't the same height, they'll tear each other up.
Also Ford duallys are bad about feathering the steers if you haul a lot. If you never haul, look into lowering the psi in the rears. Consult a load/inflation chart.
You received some good advice in this thread, particularly from Desert Don.
To validate the advice Don provided, here is Ford's position on rotating dual rear wheel tires, as printed on page 284 of the 2016 Super Duty Owner Manual, and as still recommended today in the 2023 Super Duty Owner's Manual:
If your vehicle is equipped with dual rear wheels it is recommended that the front and rear tires (in pairs) be rotated only side to side. We do not recommend splitting up the dual rear wheels. Rotate them side to side as a set. After tire rotation, inflation pressures must be adjusted for the tires' new positions in accordance with vehicle requirements.
If you only swap the rear dual pairs as a set, side to side, keeping them as pairs, and keeping them on the rear axle, then there is no potential for harm.
On the other hand, if you do the type of six tire rotation that involves splitting the dual pairs, swapping the inside dual with a steer tire on both sides, whether in a double triangle formation or some other scheme, then there is a potential to do harm, to any extent that the wear on the steer tire is greater than the wear on the outer dual tire that it is newly paired with post rotation.
If you wait too late before your initial mixed axle six tire rotation, then the potential for mismatched tire height in the reconstituted dually pairs is higher, resulting in more potential for hurt, as the taller tire in a mismatched pair can potentially become overloaded.
And then once you start a regimen of mixed axle six tire rotation, you have to maintain it regularly.
If you take it a step further, and have a tire shop break down the tires from the wheels due to only having four aluminum wheels, with designated polished sides, and two steel wheels in the mix, then the potential for hurt is magnified by the tire shop having the opportunity to scuff and damage the wheels every time they dismount and remount a tire on the rims. The tires also have to endure the tooling torture at the bead seat during each breakdown and remount session.
Given this potential for damage at the hands of any fresh faced tire jockey out of high school, on their first week on the job, who you have neither the opportunity to select or control, and given Ford's recommendation to not mix steer axle tires with drive axle tires, the jury is still out on whether you will hurt anything with your course of action.
It may be too late for you to reconsider Don's advice, but it isn't too late for future readers, hence this post.
