Towing mode
Old Jul 3, 2025 | 06:59 AM
Mfinkler's Avatar
Mfinkler
3rd Gear
Towing mode
I have a 17, 6.2, 6 speed. Is there a weight criteria on when you should be using the tow mode? My boat motor and trailer weigh about 2k pounds.
Popular Reply
Jul 3, 2025, 09:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, I am a former Ford transmission engineer. I programmed the tow mode on the 5R110W. The truck is perfectly fine in or out of tow mode at any weight. Tow mode is to make driving easier when towing, it won't hurt the truck to tow out of tow mode.
Old Jul 3, 2025 | 07:42 AM
WXboy's Avatar
WXboy
There's a guy on here who claims to be a former Ford transmission engineer. He has posted on here before that there is no threshold for tow/haul mode. Either mode will be 100% safe for the transmission.
Old Jul 3, 2025 | 09:12 AM
Mark Kovalsky
Old Jul 3, 2025 | 10:22 AM
DADDYFIGJAM's Avatar
DADDYFIGJAM
So you are not the guy that programmed the tow/haul mode on the 6.2/6r140 to double down shift on decel, running the tach over 5200rpm? Lol 😂. I love tow/haul when accelerating and on 1 gear drop on decel, but the 2 gear drop is stupid and not necessary, jmo 👍
Old Jul 3, 2025 | 10:29 AM
bpounds's Avatar
bpounds
Trust Mark. He is the go to KB for Ford tranny.
Just want to add, on both my old '06 and my new '24, what tow/haul mode does best is handle downgrade or other rapid deceleration with a load. I don't find it particularly important for climbing with a load, but it is mandatory to use it when descending, IMO. It handles downshifting for you, faster than you could possibly react manually. Combine tow/haul with cruise control on downhill grade and save your brake pads.
I thought the programming on my old '06 5 speed auto was a work of art. Maybe not quite as impressive with the new 10 speed as far as programming goes, but all those gears still makes it superior. Uphill and downhill.
Old Jul 3, 2025 | 10:27 PM
Mark Kovalsky
Not me! I left Ford the day the first 6R140 prototype was built. I never bothered to go to the garage to even look at it. I never worked on that transmission.
Old Jul 7, 2025 | 09:18 PM
Tom S's Avatar
Tom S
I like the programming in the mountains with that combo.
Old Jul 8, 2025 | 11:45 AM
kojimep's Avatar
kojimep
I don't think it's just deciding to drop 2 gears, it's just that with tow/haul active every time you pump the brakes it will downshift a gear, so it might be due to the way you are applying the brakes. If you do one long steady brake event it won't keep downshifting aggressively.
theboom
Jan 13, 2023 06:01 PM
ptt87
Oct 29, 2021 03:14 PM
AtomicNo13
May 3, 2013 08:07 AM
aquaholic
All Things Towing
22
Mar 21, 2007 05:29 PM
