Steering box adjustment results???
Old Jun 27, 2025 | 12:10 PM
josht's Avatar
josht
I'm going to go go over all the joints again before touching the steering box, but I think the box is the source of a lot of my steering play. I know that there is a procedure for adjusting the box.
For those that have tried the adjustment procedure, did it work? How were the long term results? Did the improvement last or did it go right back to being loose soon after?
Wondering if it is worth trying to adjust, or if I'd be ahead of the game getting a better steering box. I'd much rather do the adjustment if it's likely to work and last, than spend the money on a GOOD steering box (IE: Blue-Top or Red Head). I'm thinking that if I'm going to have to adjust it every few oil changes then it's worth the time and money to change it.
Old Jun 27, 2025 | 12:19 PM
z31freakify's Avatar
z31freakify
A quarter of a turn then test it, if you turn the bolt to much you risk of having memory steer and it's dangerous. And yes it usually works unless the steering box is all clapped out.
Old Jun 27, 2025 | 02:51 PM
JoshHefnerX's Avatar
JoshHefnerX
I did it about 2 years ago. Had about 2.5" of slop at the steering wheel. Got it to about half that.
Jacked up the front end, turned the wheels - engine off to feel how the ends of the steering feel.
turned in very small increments - maybe 1/8 at a time. Got up and turn the steering wheel - see if any 'feel' changed - tightness. did that several times, until I'd reduced the slop. I did not want over do. and it's been livable for 2 years.
You can easily go too tight - it will start to stiffen/bind at the full locks. You will break stuff.
After 2 years, all that being said. I have a new PSC unit in the front room waiting for cooler weather. As I don't want to go further and 1.5" of slop is still too much.
Old Jun 27, 2025 | 07:59 PM
kbeefy's Avatar
kbeefy
I tried adjusting mine before I put on a redhead.
I'd suggest adjusting it at close to full lock. I found, on mine, that there was almost no wear except in the center. (you know, where the wheel is 99% of the time) When I tried to adjust out the wear in the center the ends would get too tight.
Old Jun 27, 2025 | 09:17 PM
John in OkieLand's Avatar
John in OkieLand
What components did you buy, and how bad did it hit the wallet?
I have been contemplating getting the PSC, because my Steering is so STIFF, it takes two hands to turn the wheel.
it got immensely worse, after I had it aligned and the castor raised from 2 to 5 degrees.
it will self center back on the road, almost, I have to help it the last 1/4 turn.
Old Jun 27, 2025 | 09:47 PM
JoshHefnerX
https://www.summitracing.com/parts/PFN-SG752
and a new shaft to be sure.
https://www.summitracing.com/parts/BRG-000306
There was 7 about 2 weeks ago when I was mulling this over and 4 left when I bought mine a week or so ago. So they're moving fast only 2 left now. I called PSC with a question - and they were out of stock and didn't have an eta, so may be unavailable for a bit if you hold off too long.
I also have the saginaw conversion sitting next to the box in the front room.. Again waiting for cooler days.
Old Jun 28, 2025 | 06:37 AM
AdamDenver's Avatar
AdamDenver
This right here is the post to follow. I did the exact same thing and pulled my slop from over 5 inches down to 1. It's lasted 2 years here too. I tightened 1/4 turn after it was an inch of slop and it didn't change, so I stopped. I know a new blue Top is in the future, but right now I got work to do.
Old Jun 28, 2025 | 08:12 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I adjusted my OEM steering gear a bit when I first bought the truck. Ultimately the adjustment still fell very short of what I thought the steering response should be. I installed a "Blue Top" steering gear and all has been well since.
The adjusting did make a big difference, but I was uncomfortable with the steering at 55 MPH on the interstate towing the 5th wheel and going through concrete barriers in construction zones. It was not a good scenario to put myself, the truck or the other drivers into.
Zero regrets about going with a remanufactured box from a reputable source. Stay away from the parts stores, I had two of those boxes in the truck prior to the Blue Top and they were garbage from day one.
Old Jun 28, 2025 | 01:32 PM
JoshHefnerX
I pretty much knew that I was eventually going to replace the box at some point. The adjustment can give you a bit of life turning something that may be borderline dangerous to usable. But you're not going to get a new box out of it. It will help though. And can buy you some time.
Another thing is several people have found slop in the steering shaft. A small fraction of a degree at the shaft will turn into a fair bit at the rim of the wheel.
Old Jun 28, 2025 | 02:26 PM
INFRNL's Avatar
INFRNL
I tried adjusting mine and screwed up. bought a redhead way back, blue top wasn't even a thought. It's been fine and probably has the typical break in play now.
If I had to do it again today, I am not sure what i would do...probably something with a PSC and dump the POS ps pump. I'm on 35's and there's times it doesn't want to move them well.
I faintly remember talk about gear boxes and upgraded hydroboost units, etc. not sure what the best options are anymore
77_f250_custom
Apr 21, 2015 07:17 PM
BluesManF250
Jan 11, 2004 11:27 PM
