Steering Damper
Old Apr 20, 2015 | 08:18 PM
77_f250_custom's Avatar
77_f250_custom
Steering Damper
Hey guys. Quick question: I have some steering slop in the box. I've put all new parts in the steering itself, and adjusted the adjusting screw on the box. However, my steering box is just on its last leg. Will a steering damper help take the slop out until I can afford a red head box, or am I doomed to a wandering truck?
Old Apr 20, 2015 | 09:29 PM
co425's Avatar
co425
A steering dampener isn't for fixing sloppiness. Save your money from the dampener and put it towards that red head box.
Old Apr 20, 2015 | 09:36 PM
Jdeshler's Avatar
Jdeshler
I have personally had many of these trucks and have never seen one too far gone. That bad boy must have had a lot of cranking through the years..
I agree to go for a new box, it must be very unsafe if its been adjusted and is still sloppy
Old Apr 20, 2015 | 09:48 PM
77_f250_custom
Yeah I worried that would be the verdict. Adjusting it helped a bit, new tie rods and such helped, but its still got play. This truck has definitely had a rough life.
Old Apr 21, 2015 | 01:04 PM
krazyness's Avatar
krazyness
What about rag joint? (If equipped)
Old Apr 21, 2015 | 02:37 PM
77_f250_custom
It's good. The only reason I know it is the box is if I rotate the steering shaft right where it enters the box (after the rag joint) by hand, I get about 1/8th of a turn before the pitnam arm moves...
Old Apr 21, 2015 | 07:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Also look into a Borgeson steering shaft on the "saving up for" list.
Borgeson Universal Steering Components
ved0303
May 16, 2016 10:58 AM
CanadianSmokie
Oct 25, 2007 11:28 AM
