Y block temp sensor questions
Old Jun 25, 2025 | 11:50 AM
my1955F100's Avatar
my1955F100
So my 55 had the original, and very tired, 223 in it when I got it 10 years ago. In '19, I found a 292 Y block from a 58 F100. After a rebuild, I did the swap and life's much better under the hood. The only issue I've had is with the temp sensor located on the back of the intake, drivers side. The threaded hole is too large for the 292 version so I picked up a 1/2" reducer which you can see in the pic. It's not OEM so I ordered a sensor adapter from Dennis Carpenter but can see it's not threaded on the outside for install on the intake, just the reduced diameter for the sensor. Does anyone have any ideas or experience with this? Many thanks in advance.
Old Jun 25, 2025 | 12:07 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
I would encourage you to read through this to get an understanding of the various systems and possible options:
https://www.ford-trucks.com/forums/1...re-switch.html
BayStYat
Apr 23, 2021 02:33 PM
ozziesstang89
Aug 2, 2019 12:35 AM
varminthunter243
Mar 15, 2016 11:26 AM
Florida 350
Feb 1, 2015 07:25 AM
seawulff
Nov 24, 2005 08:18 PM
