Temperature Sensor?
Old Nov 24, 2005 | 07:18 PM
seawulff's Avatar
seawulff
Temperature Sensor?
I am taking out some after market gauges that the PO put under the dash and the temp sensor goes to a bolt which screws into the block on the drivers side of the engine to the rear of the carb. Is this an after market temp sensor and is it a water temp sender. If I disconnect it what do I put in it's place I really don't want to use the after market gauges. I bought a new wiring harness and am trying to install it. By the way it's '56 F100 with a 312 Y-block. Thanks and Happy Thanksgiving.
Old Nov 24, 2005 | 08:18 PM
Overkill-F1's Avatar
Overkill-F1
If you don't need the hole in the block for an original temp sender, then you can plug the hole. It should be a pipe tap threaded hole (npt). ...Terry
ottoparts
May 7, 2014 06:05 AM
danevans
Nov 17, 2008 08:13 AM
mr clutch
Jan 15, 2006 11:38 AM
bitesomthing
Mar 25, 2005 11:07 PM
HiDesertRat
1983 - 2012 Ranger & B-Series
Dec 22, 2004 02:17 PM
