Please help!!!
Old Jun 11, 2025 | 05:48 PM
Help me not hate truck's Avatar
5th Gear
Please help!!!
Truck: F450, 2013, 99765 miles, Lariat, 6.7
Symptom: squalling sound from back of 6.7 motor. Using a hose for an ear pace, the sound is coming from behind turbo and upper intake man a fold.
What I have done thus far is:qqqqqqqqqqqqqq
1. changed fuel filters
2. water pumps replaced
3. vacuum pump replaced
4. fan drive pully replaced
5. belt replaced
6. fan drive pully replaced
7. replaced both radiators
8. aftermarket oil and trans cooler
Things I have checked:
1. no suet (smoke residue) on fire wall or back of motor.
2. radiator fluid on side of block (passenger side) very minimal
3. on a long trip tuck will use a qt of radiator fluid.
4. no codes
Things I don't think it is:
No banshee scream, so exhaust studs and manifolds should be good.
No grinding or chattering from trubo.
More useful info:
The squalling does not happen at startup only after 1st rev, or letting idling for a few mins.
Inter guess are:
turbo up pipe gaskets, something with EGR, broken manifold studs,
Please with what it or what to check.
thank you in advance.
Old Jun 11, 2025 | 06:44 PM
speakerfritz's Avatar
speakerfritz
can you put up a video of the sound
is the coolant consumption a leak out side of the motor like the lower radiator hose from engine to radiator or is the leak from an internal engine issue?
do you have any codes?
Old Jun 11, 2025 | 07:31 PM
F250_Super_4X4's Avatar
F250_Super_4X4
Have you checked for play in your turbo impeller?
2011-14 Turbos are known for bearing issues. Check side to side and end to end.
Initial sound will be a hum, then a pop and hum, then a squeel.
Old Jun 11, 2025 | 09:36 PM
5th Gear
no codes, after 2800 miles I lost a qt if that makes a difference. the coolant is on side of block EGR side
here is a link to video
the yard stick is where the noise is coming from.
https://1drv.ms/v/c/88f3b7b8c474b8d3...9ERSR6SbBRL8oA
Old Jun 11, 2025 | 09:38 PM
5th Gear
will check tomorrow here is a link of the sound. the yard stick is pointing where the sound is coming from.
Old Jun 11, 2025 | 09:55 PM
5th Gear
Originally Posted by speakerfritz
can you put up a video of the sound https://1drv.ms/v/c/88f3b7b8c474b8d3...9ERSR6SbBRL8oA
Cannot find the leak just a wet spot.
no codes
Old Jun 12, 2025 | 08:21 PM
speakerfritz
you should put the file on you tube….that way it can be heard/viewed with out a login.
right now, your file wants to launch in one drive and it wants me to pass along my userid and password.
that would be risky Business now a days.
Old Jun 13, 2025 | 07:21 AM
SavageNFS's Avatar
SavageNFS
This was a really nice way to word this. I don't know if the OP is legit or not, but I stopped caring (and thought scam) when it went to a log-in screen and just moved on. No offense, but I'm not giving up any log in info to help a maybe with 5 posts. Maybe it's legit, but with all the BS going on with scams, the OP should have thought about it. It's not hard to put something on YT.
Old Jun 13, 2025 | 08:33 AM
Overkill2's Avatar
Overkill2
x3 after I saw the one drive log in pop up.
Monster-4
Jun 12, 2019 07:01 PM
HTM101
Nov 5, 2018 09:30 AM
nonoodlez
Jul 11, 2012 09:08 AM
StuntCowboy
Feb 12, 2010 05:35 PM
wdtowing
Jan 3, 2009 09:24 PM
