6v positive ground battery install
Old Jun 10, 2025 | 06:22 PM
8pack's Avatar
8pack
Ok, so I have gone through the thread in the link below multiple times and I think I have it all sorted out based on looking at the pictures etc. I want to be sure I have it right as I don't want to fry anything and set myself back.
Positive battery terminal to engine block (or frame but block is preferred)- 00 Cable
Negative Battery terminal to right side of Solenoidwith the 2 yellow wires coming from the Harness. 00 Cable
Left side of Solenoid to Starter - 00 Cable
Block to frame - Braided cable
Block to cab - Braided cable
A couple of questions:
Can I use regular cable for the block to frame and block to cab or is there a reason to use braided cable instead?
Where on the cab are you mounting the ground from the block?
https://www.ford-trucks.com/forums/1...cal-6volt.html
Image from the thread I linked to. I used this as a guide. Left side of solenoid to starter. Right side to negative battery terminal
My solenoid with the 2 yellow wires from the wiring harness on the right side of the solenoid.
Old Jun 10, 2025 | 07:08 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Braided cable is thought to be more tolerant to repeated flexing and so it is used between items that flex (engine vs body).
In general, I like to recommend B14 and B14G braided cables as the are generally available.
Old Jun 10, 2025 | 08:17 PM
abe's Avatar
abe
Positive ground to the frame was stock original and has served my 54 well for 71 years. Just make sure you have a clean contact point with no rust (which I know your frame is good) and no paint.
If you don't have braided cable, welding cable, which many of us use anyhow, is very flexible.
Old Jun 10, 2025 | 09:15 PM
jniolon's Avatar
jniolon
old and in the way
al good info above. Just find a fine strand cable like welding cable and you'll be fine. I'll only add that I like soldered
connections over crimped... but most folks don't have the 'heat' to solder big cable. Don't use "walmart" connectors
go to a welding supply house and buy good connectors sized to your wire.
this is the crimper I use for the big stuff
Amazon Amazon
john
Old Jun 11, 2025 | 05:57 AM
8pack's Avatar
8pack
Follow up questions;
Can I use welding cable for all my connections (battery, solenoid etc) as long as it is sized properly at 2/0? It is a more affordable solution overall.
Where is the best place to ground to the cab?m
Thanks All! On the list to try and complete the wiring this week.
Old Jun 11, 2025 | 07:11 AM
bmoran4's Avatar
bmoran4
What folks here have been calling "welding" cable, they technically mean a wire that is made up of a very high number of very small strands. Your typical battery cables will have 19 or 37 strands of "spaghetti" sized copper. The "welding" cable will have something like 1254 strands of very fine copper. The higher the strand count, the more flexible it is. It is also sometimes referred to as class K wire.
It is fine to use that high strand count wire for all your connections. Be sure to use the proper terminals and crimp them with an appropriate tool. These are not things you want to solder.
Old Jun 11, 2025 | 09:02 PM
jniolon's Avatar
jniolon
old and in the way
here's a table showing strand count
Old Jun 11, 2025 | 09:17 PM
bmoran4's Avatar
bmoran4
It can vary depending upon manufacturer and product.
Old Jun 11, 2025 | 09:31 PM
8pack's Avatar
8pack
Based on that table it looks like if you use welding cable you can go down in size and still support the same amps.
That makes things a little easier and less expensive as well if correct....True?
Old Jun 11, 2025 | 09:52 PM
bmoran4's Avatar
bmoran4
I wouldn't. It isn't worth the very few tens of dollars difference. 6V loves thick wires.
Old Jun 12, 2025 | 07:55 AM
hooler1's Avatar
hooler1
I would ground the cab at the firewall.
Just another grounding suggestion. Ground your positive battery cable at your engine block. A starter mounting bolt even, and then use that point or another convenient point on the block to run a ground to the cab's firewall and a ground to your frame. When cranking you want every amp of that batteries current to run right to the starter, or block.
It's just a good reference point use use as a main ground since your ignition uses your engine for its grounding point and your charging system assuming you have your generator/alternator and voltage regulator grounded properly.
This is just my opinion/suggestion I guess.
Old Jun 12, 2025 | 09:34 AM
8pack's Avatar
8pack
Thanks!!!
PotomacEd
Electrical Systems/Wiring
Jul 6, 2023 01:23 AM
Schuyles
Oct 31, 2018 05:26 PM
Shake-N-Bake
Sep 22, 2014 11:27 PM
john fin
Nov 22, 2011 09:43 AM
Spydycarnge
Dec 27, 2009 09:40 PM
