Ram style power steering...?
Old Jun 1, 2025 | 10:11 PM
hooler1's Avatar
hooler1
Originally Posted by cokefirst
I own several (too many) mid 50's Ford vehicles that use that clamp with the rubber insulators to hold the power steering hoses to the frame. I did the exact same thing. I have a small parts department for my cars and I keep about 500 or so part numbers in stock. I was not pleased about the single flare fittings. CPP assembles this item at their shop in Placentia California, and they are car guys, so they should know you don't use a single flare on a hydraulic fitting. I will take a photo of the routing of the hoses when I get to the shop tomorrow. what pump are you using? The GM pump is a little high pressure for the ram set up. I use Eaton pumps.
LOL, Yes I have the same frustrations about the CPP single flared ends. I can't remember what that hose kit cost me, as it was several years ago I ordered it, and it turned out to be unusable. One thing I might do is get 45 degree angled ends where the hoses connect to the sector valve. The ports at least to the RAM stick out 45 degrees, so with using a straight fitting it will stick out and rub into the tire on good left turn. On mine the PO bent his fitting necks 45 degrees to make them a straight run so they would get more clearance to the tire but he also kinked them a little doing that
As far as a power steering pump, I am running a 69 302 so I am using what the PO installed. The early 60's style Ford/Thompson pump. It seems to work pretty well.
slow2v
Jun 26, 2015 03:57 PM
Damifiknow
Feb 19, 2012 12:01 PM
55 Ford-O-Matic
Feb 2, 2008 12:48 PM
dstruble
Jan 16, 2006 07:59 AM
1968 F250camper
Feb 23, 2005 06:22 PM
