TPS
Old May 8, 2025 | 07:36 PM
mat-it's Avatar
mat-it
TPS
So I've been trying to fix a rough idle issue and I'm wondering about the old original TPS. When I look at Rock Auto they list them with an air pump and without.
Is there an important difference between these? I ask because this '96 5.8L has been modified and the air pump has been removed. Not using the stock ecu, using a tunable one.
Old May 8, 2025 | 08:03 PM
Soup bean's Avatar
Soup bean
I'm not familiar with tunable ECUs or '96 trucks, but here's how to test the TPS https://www.fullsizebronco.com/threa...stment.203080/
Old May 8, 2025 | 10:21 PM
mat-it's Avatar
mat-it
Thx, but given this thing is 30 years old I’d like to replace it. Just wondering why there are 2 part numbers, they don’t look different in their photo.
Old May 9, 2025 | 08:09 AM
manicmechanic007's Avatar
manicmechanic007
Must be a brain fart on Rock Autos part
The TP's are the same
Try to find a Motorcraft one NOS on Ebay
You are right
The TP is the only moving part except for the injector pintles, means they DO wear out
Old May 9, 2025 | 08:17 AM
wwhite's Avatar
wwhite
I just looked, and yes they are different, in the plug, have a look at the pictures.
More than likely, with 1996, on uses OBDI(EEC-IV) and the other is for OBD2(EEC-V).
Also in 1996, I believe that the OBD2 vehicles did not have an Air Pump.
In reality, the distinction should be OBD1 vs OBD2, not with/without air pump.
STANDARD MOTOR PRODUCTS TH184 Info OE No. F6TF-AA
- has a 4 pin plug with only three wires, square looking
STANDARD MOTOR PRODUCTS TH44 Info OE No. E7TF-CA
- has a 3 pin plug with three wires, triangle looking
So, question would be, is there an early vs late difference in plug, or is it OBD1 vs OBD2 actually the difference?
Old May 9, 2025 | 09:15 AM
mat-it's Avatar
mat-it
Yes, the shape and pins of the connector plugs are different. This truck came with obd1 and air-pump so all is good.
Thx
FreeBird101
May 26, 2023 09:58 AM
kupaa
13
Jun 16, 2010 04:40 PM
truknut1972
Aug 23, 2008 10:09 PM
870
Oct 7, 2007 01:34 AM
bodabdan
General Automotive Discussion
Apr 13, 2005 08:42 PM
