changed my HPOP
Old Jun 16, 2010 | 03:04 AM
kupaa's Avatar
kupaa
changed my HPOP
Just changed out my stock pump for one of Joey's modded pumps, anyways can i leave the truck running at idle for 5 hrs at work to let out the air or do i have to drive it around?
Old Jun 16, 2010 | 04:58 AM
ron's power stroke's Avatar
ron's power stroke
best to drive it and push the air with PSI...at idle the air bubbles just might not move..they will stay in the high spots...
Old Jun 16, 2010 | 06:32 AM
01 EXCURSION MORRIS's Avatar
01 EXCURSION MORRIS
Do you notice a difference in the seat of the pants?
How much did it cost to get pump modded?
I'm thinking about it.
Old Jun 16, 2010 | 07:08 AM
rat49f6's Avatar
rat49f6
I have installed 2 of Joey's pumps now and I wouldn't say its a SOTP difference as much that its,a feel difference. Let me explain, after a good hard pull in 120 r the injectors would have excessive clatter with the 15° pump(held 1300 psi). After changing to a stock 17° pump (holding 1900 psi) the clatter was still moderate but quieter and shorter. Finally with Joey's modified 17* pump (holdding 3000+ psi )the clatter is nearly non existant. For the $100 and week of down time I have piece of mind that my injectors arent running out of oil.
Old Jun 16, 2010 | 08:27 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You've got to be s******g me...only $100?!? I'll send mine of tomorrow if I can get a steady 3000 psi for only $100!
Now that I'm past the excitement, what did it REALLY cost you?
Old Jun 16, 2010 | 09:06 AM
HKusp's Avatar
HKusp
Yeah, inquiring minds want to know....
Old Jun 16, 2010 | 09:20 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Joey modding the pump really does bring it up, but also remember that Jim is running 'AB' injectors which use less an 'AD'. It also depends on the shape of the donor pump. For less than $100 it is a great option and probably the best IMO besides goint to duals. Joey has a new pump coming out soon that is even better than the modded pump, so don't jump to soon, you may miss the big one
Old Jun 16, 2010 | 09:52 AM
rat49f6's Avatar
rat49f6
And ill have that pump too...Just because
Old Jun 16, 2010 | 10:12 AM
Toreador_Diesel
Well it's either that or an Adrenaline pump for me...
Old Jun 16, 2010 | 10:26 AM
kupaa's Avatar
kupaa
yep 100.00,haven't drove it yet finished late last night.going to change oil today and fire it up then i will let you guys know...............
Old Jun 16, 2010 | 10:34 AM
brownie83's Avatar
brownie83
jim just did mine last weekend...not too much seat of pants feel...but at lower rpms i have much more power. i dont have to down shift(6spd). mine doesnt run as strong as jims, but it is really good. we also did clays Frx and Hrx...really quieted the engine down. love the parts...thanks jim and clay
Old Jun 16, 2010 | 10:42 AM
rat49f6's Avatar
rat49f6
Update that signature
Old Jun 16, 2010 | 10:49 AM
brownie83's Avatar
brownie83
just did it bro...have been working like crazy since coming home. fixed cruise...it was the switch. how can i test the icp? i dont want to spend bucks if i dont need it.
Old Jun 16, 2010 | 04:40 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
just put your truck in first gear and drive around with the rpms at 2K for about 5 minutes and that will do the trick. besides it will be alot cheaper than 5 hours worth of idling......
