How do I reprogram factory keyless entry code?
Old Dec 5, 2003 | 11:34 AM
jbookrun's Avatar
jbookrun
I need to change the factory keyless entry code on my '98 Explorer.
Is this something I or the dealer can do?
Old Dec 5, 2003 | 05:48 PM
1956MarkII's Avatar
1956MarkII
The factory code is on a module, inside the area where the jack is kept. The module is FORWARD of the wheel well, so it's very hard to see. It's a 5-digit code, in type larger than the other numbers on the module. Once you have that, you can use the code to enter you own personal code (the code on the module is permanent and will always work). Your owner's manual will tell you how to enter your own code.
Old Dec 5, 2003 | 08:33 PM
jbookrun's Avatar
jbookrun
Thanks, but I'm looking to CHANGE the FACTORY keyless entry code. This code is in the wrong hands and I need it modified.
Can this be done without getting the dealership involved?
Old Dec 5, 2003 | 10:10 PM
CC77's Avatar
CC77
Maybe.
http://webpages.cwia.com/~bdklein/sho.htm
It's not an Explorer, but the procedure might work just the same. It's worth a shot, right? Open everything up and see what you're working with. If it's the same, follow the procedure. If not, get yourself an after-market alarm system with keyless entry (do-it-yourself for under a hundred bucks from crutchfield.com) and then unhook your keyless entry system altogether. That should do the trick.
Good luck!
Old Dec 6, 2003 | 12:02 AM
sllt96xlt's Avatar
sllt96xlt
yes you can change it. the directions are in the owners manual. if you don't have it. then call the dealer.
Old Dec 8, 2003 | 10:42 AM
Jet Lizard's Avatar
Jet Lizard
Yes, as I remember, Owner's manual has some information about changing factory code for keyless entry. If you don't have one, Ford owner's manuals are available on-line at www.qualitycareservice.com , free of charge (but only for vehicles produced after 1996).
Good luck,
Yuri,
Moscow, Russia
Old Dec 8, 2003 | 12:57 PM
99Xplr's Avatar
99Xplr
I don't believe that you can change the factory code without getting the dealer involved. It is "burned" into the ECU.
Old Dec 8, 2003 | 12:58 PM
99Xplr's Avatar
99Xplr
What the owner's manual talks about is adding a second personal code. It mentions speifically that it will not over write the factory code.
Old Dec 8, 2003 | 04:54 PM
emtabmm's Avatar
emtabmm
Keep in mind also, if you enter your own personal code, any time, and I mean any time the battery goes dead, is unhooked, whatever, that personal code is lost and system reverts to factory. I got so tired of reminding the wife of the original I made her memorize the factory code.....
Old Dec 8, 2003 | 04:55 PM
emtabmm's Avatar
emtabmm
Yes, go to a salvage yard and purchase a keyless entry module....
crozz
2004 - 2008 F150
Sep 26, 2016 08:16 AM
cassenbl
Apr 7, 2015 12:33 PM
dukman22
Feb 5, 2007 07:48 PM
excursion2001
General Automotive Discussion
Feb 9, 2004 10:10 AM
otismojo
Apr 29, 2002 03:03 PM
