What keyless entry module? I thought the RKE was controlled by the GEM. Is that what you are referring to? I've never looked at it to see if a code was on it. I will tomorrow.
My manual doesn't show a keyless entry module. Now, that's not to say it isn't there... It just means my manual doesn't show it. Hey, whadya want for $20!
The owners manual for 2000 says the factory 5 digit code is taped to the computer module. There is a RAP (remote anti-theft personality) module that works with the GEM to run this system. Remove the LH front door scuff plate and the cowl side trim panel for axcess (from 2000 factory manual).
I removed the skid plate from the driver door and the front kick panel and did not see anything related to the keyless system. There was not special module with the number on it. Maybe I did not understand where to look per the instructions. If I was off please offer me the correct simple for dummies instructions as to where to look.
