Is it worth having a tach?
Old Apr 16, 2025 | 08:35 PM
Binky7.3's Avatar
Binky7.3
When I bought my van, I found evidence that several gauges had been installed at one time.
The gauges were gone, but the sensors were there with the wires clipped off. Including the tach lead. I I didn't think anything of it, assuming it had been used to drive an accessory tach, and I had read that the idi vans didn't have one stock. So, many things about these trucks are new to me. I really wanted to see what was going on and installed one, using the cut leads.
Turns out I needed that signal for my E4OD! I'm replacing the sensor thinking that will fix my current issue. With that fixed, I lose my tach. The wiring diagram shows a tach signal out lead from the TECU for the F-series and Broncos...
I think I can use that pin to run my aftermarket tach, but is it worth It? It sounds like one can't really over rev these due to internal controls, correct? Is RPM data really worth having if you have an automatic? Not since my 67 Catalina have I had a vehicle without one. Even my previous gas van had one. But with more of a torque plateau than a curve, is a tach worth having. I'm sure I could use the pillar pod space for a different gauge.
John
Old Apr 16, 2025 | 09:14 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
I don't think so. You're right, the IP is governed so it can't over-rev anyway. So long as your sensor is giving the trans controller the info it needs to shift properly, it's all you need really. Worth having a tach gauge is very subjective and of course only you can decide that, but it's nowhere near as important as oil pressure, engine and trans temp, for examples.
Old Apr 16, 2025 | 09:46 PM
Binky7.3's Avatar
Binky7.3
Thanks. I have engine/trans temp and EGT in my pillar. I'll add a multi guage in the soon to be unused pod.
John
Old Apr 17, 2025 | 06:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
i think i have had a tach in every vehicle i ever drive.
and the only one i ever used was on the 49 International L190, and that was only used to set engine RPM for the proper PTO speed.
i never look at the tach while driving.
Old Apr 17, 2025 | 08:57 AM
Binky7.3's Avatar
Binky7.3
That's why my van had the accessory tach. There was a PTO on the BW1356 to run the crane.
I won't worry about it then. Thanks!
John
Old Apr 17, 2025 | 09:46 AM
WCMtn1990's Avatar
WCMtn1990
You don't need it but I do like having a tach so I can see where the E4OD is shifting or where the IP de-fuels.
Old Apr 17, 2025 | 09:57 AM
Olds64's Avatar
Olds64
Does the FIPL use vacuum the way a VRV does? If so a vacuum gauge would be more important than a tachometer.
Old Apr 17, 2025 | 11:11 AM
tjc transport
i ain't rite
no the throttle position sensor i strictly electrical.
s far as vacuum gauge goes, i know when the vacuum pump is going bad, the C-6 trans starts shifting funny, and the power brakes are only good for one or two quick stabs before going hard.
also the heat/ac diverts to defroster.
Old Apr 17, 2025 | 02:13 PM
Olds64's Avatar
Olds64
I've had a failed vacuum pump on my Bullnose truck more than once. Quality of parts these days.
Since there's no need for a vacuum gauge a tachometer wouldn't be a bad idea. I think an OE tachometer would be awesome.
rmalottwtes30
Dec 2, 2008 10:23 PM
dyoungen
Feb 28, 2008 10:21 AM
Nathan Britt
Modular V10 (6.8l)
Nov 6, 2006 02:31 PM
TopThis8899
Jul 27, 2006 07:55 PM
