1984 Transmission damage
Old Apr 18, 2025 | 03:37 PM
NateChristy's Avatar
NateChristy
Hi I just went under my truck and noticed the bell house and cover I believe was cracked to **** as well as a very dented oil pan where would be the best place to get a replacement.
Old Apr 18, 2025 | 03:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
that is simply a clutch cover.
it is made out of stamped sheet steel.
Old Apr 18, 2025 | 04:12 PM
NateChristy
Fantastic, thanks for the help i know it was likely a simple question but appreciate the help as I'm just starting to learn all this! Where would be the best place to order a new one?
Old Apr 18, 2025 | 04:22 PM
85e150's Avatar
85e150
Pull it off and straighten it out. Hammer, pliers, big block of wood......
Old Apr 18, 2025 | 04:54 PM
Olds64's Avatar
Olds64
Unfortunately, you'll only find that cover on another truck. Likely with the same transmission. You won't be able to get one at your local auto parts store. You could check LMC Trucks.
https://www.lmctruck.com
Old Apr 18, 2025 | 05:35 PM
tjc transport
i ain't rite
agreed. i dont think they have been manufactured for around 20-25 years as the last of the 4 speed manual transmissions with detachable bell housing on diesel trucks was around 1987.
by 1988 ford switched to the 5 spred ZF manual trans with integral bellhousing.
the "crack" is supposed to be there. and the bent part is easily removed with a hammer and block of wood. i have straightened way worse pieces than that.
Old Apr 19, 2025 | 10:03 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
You don't even need to mess with it if you don't want. As long as it's not rubbing and grinding against the flywheel, it will never hurt anything.
huesostew
Jan 30, 2024 09:48 AM
Fordbronco69
66
Sep 18, 2016 02:55 AM
Meydawg51
Jan 11, 2015 08:48 AM
Crewcab Turbo
18
Jun 21, 2013 01:21 PM
robles4242
15
Oct 13, 2010 09:41 PM
