Tach gone crazy
Old Nov 30, 2008 | 09:35 AM
rmalottwtes30's Avatar
rmalottwtes30
Tach gone crazy
When driving down the road my tach is starting to bounce around, and when at idle it goes to 0. When I got home last night and parked the truck and looked at the tach it read the normal 700RPM, what could be making the tach read wrong and bounce?
Old Nov 30, 2008 | 10:19 AM
farmert's Avatar
farmert
My first guess would be the tach sensor on the engine. Check to see if the wires coming out of the nut are bare. On my 85 the gauge itself went bad, and I had to reolace it with the tach from my parts truck.
Old Nov 30, 2008 | 11:28 AM
LCAM-01XA's Avatar
LCAM-01XA
Must be nice not having an E4OD now, ain't it? If you did those tach issues would have mede for a very interesting trip home. But yeah, like Farmert said, check your tachometer sender on top of the IP gear housing, insulation on wires shrinks with heat from hours and hours of engine running and the wires go bare, sometimes enough to touch each other and short, causing all sorts of havoc at the tach.
Old Dec 1, 2008 | 10:20 PM
imboostedru's Avatar
imboostedru
I am having the same problem with me 94. The other thing i noticed is that the tach jumps when the turn signals are on. Would this mean more of a gauge problem?
Thanks
Shawn
Old Dec 2, 2008 | 12:11 AM
starmilt's Avatar
starmilt
I would say a ground problem.
Old Dec 2, 2008 | 09:55 PM
Dave Sponaugle's Avatar
Dave Sponaugle
imboostedru,
Welcome to FTE and the IDI diesel forum.
I am going to second the ground problem.
There is a lot of metal under the dash that is not grounded.
Same under the hood.
Start checking ground straps and wires, headlights, body to engine, body to frame (both front and rear) and under the dash.
Old Dec 2, 2008 | 10:00 PM
imboostedru
Thanks for the tips. I will check them as soon as I can get off work before dark and if it ever stops raining here(WA). Where are the grounds under the dash?
Shawn
Old Dec 2, 2008 | 10:23 PM
David85's Avatar
David85
I would say loose contact. Either a ground or some other connection. Bouncing from normal down to zero and back means total power loss for brief moments when the power is cut. If there was an internal problem with the tach or the sender, I would expect a more stable but lower signal.
oldboots1950
Apr 13, 2015 07:28 AM
scottscott
Apr 22, 2010 04:08 PM
DieselBeast01
Apr 15, 2009 10:56 PM
Kijutsu
1983 - 2012 Ranger & B-Series
Aug 22, 2008 01:46 PM
jwolfe60
Nov 27, 2007 05:41 PM
