VGT Harness Clip
Old Apr 14, 2025 | 08:36 AM
Bruin008's Avatar
Bruin008
VGT Harness Clip
Looking for the part number or link where I can get the VGT Harness Clip. Parts guy couldn't find it. It holds the wire for the VGT. Gets bolted to the front of turbo.
Old Apr 15, 2025 | 10:59 AM
Baylinerchuck's Avatar
Baylinerchuck
If it were me I’d just go to a local junk yard and try to find one. Maybe someone here has an extra they can send you. I’ve also seen these clips come with a gasket kit that KC Turbo sells. They may be another good source.
Old Apr 15, 2025 | 11:29 AM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
Took some digging but I figured it out, you won't like the answer. It only comes with the turbo. Unless you can figure out who supplies them to Garrett that is. Used might be your best bet.
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Old Apr 15, 2025 | 01:59 PM
joe blow's Avatar
joe blow
Why not just use a standard cable clamp with a bolt to the compressor? Unless you really need to have the OEM.
3/16
Old Apr 15, 2025 | 02:54 PM
bismic's Avatar
bismic
Nice to see ya'll posting in the 6.0L forum!
Old Apr 15, 2025 | 03:41 PM
AppleFordParts
SPONSOR
I'm trying to get around.
__________________
Old Apr 15, 2025 | 05:14 PM
TooManyToys.'s Avatar
TooManyToys.
Old Apr 15, 2025 | 09:18 PM
Bruin008's Avatar
Bruin008
No related to this, but Too Many Tools. You're use if a Adel clamp to lift the head is so awesome. I ended up getting a clamp and a special bracket. The bracket worked to get the head off but we fought it. Come to find out, the bracket leaved the head straight up and down. Your use of the Adel clamp saved the day and probably ruining the gaskets. Thanks abunch!
Bruin008's Avatar
Bruin008
I'll probably end up having to. Just factory looks better
Old Apr 15, 2025 | 09:20 PM
Bruin008's Avatar
Bruin008
thanks. You....as in the business....is who I got all my parts from for the head gasket repir.
Old Apr 15, 2025 | 09:34 PM
TooManyToys.
>> Your use of the Adel clamp saved the day and probably ruining the gaskets. Thanks a bunch!
Sometimes it's the little things - You're welcome.
zackford94
Apr 7, 2025 07:49 AM
HeavyAssault
May 6, 2024 08:14 PM
66F250_4x4
May 18, 2023 07:24 PM
Aaron Johns
Sep 30, 2022 09:41 AM
Rob89
Jun 27, 2021 10:55 AM
