Cyl#1 is dead
Old Apr 13, 2025 | 07:57 PM
Horsethief's Avatar
Horsethief
Cyl#1 is dead
1973 f100 with fe390, and a c6
Started truck up at work to head home the other day, and noticed the lumpy idle right away, but started instantly upon touching the key. Limped it home, and squirted some water on headers to find cyl #1 cold. Had a busy weekend, but replaced plug wires, as its been a few years, and pulled #1 to find a clean washed plug soaked with gas. Swapped that plug out to no avail-still cold. Cleaned up the dist cap-nope. Swapped the cap, and still nope. Checked spark at #1 plug, and i have spark, but hard to tell how good it was with my old eyes, and the bright sun. I am gonna pop the valve cover when i get a chance, but what would i be looking for besides obviously broken parts at that cyl? Its getting gas, and spark already. No signs of oil on plug at all. Thanks!
Old Apr 13, 2025 | 08:10 PM
440 sixpack's Avatar
440 sixpack
I would blow it out and replace the plug before I dug into it too far. possibly swap a plug wire too.
Old Apr 13, 2025 | 08:25 PM
Horsethief's Avatar
Horsethief
As in dry out the cylinder? Plug wires got changed this afternoon without change. threw a lightly used, and cleaned plug in as well
Old Apr 13, 2025 | 10:05 PM
440 sixpack
if you're sure you have blue spark , and you say there was gas in the cylinder, then it has to be mechanical.
if it happened all the sudden hopefully it's a pushrod or rocker.
Old Apr 13, 2025 | 10:11 PM
Horsethief's Avatar
Horsethief
Yeah. Hoping for a pushrod, as I've had to replace 3 of them over the past few years. Bent 2, and had one end turn egg shaped due to a clogged oil hole.
Would an intake gasket leak at that cyl do this?
Old Apr 13, 2025 | 11:49 PM
440 sixpack
No, it would run lean, which would run hot.
Old Apr 26, 2025 | 09:23 PM
Greaser007's Avatar
Greaser007
@Horsethief
My guess is if you've bent a couple of pushrods earlier, you may have tight valves, and One that has stuck.
When I do a first start on an engine that has been sitting, I use 2-stroke fuel for initial starts (to help lube valve stems).
This is probably just a 'pipe-dream', but maybe the 2-stroke oil will be of benefit.
I have bent pushrods from valves Sticking both from extended sitting, and from bad fuel.
The curse is, if you had bent a push-rod, you would think you'd be hearing a Clicking.
Let us know what you have discovered. thanks, and good luck
DarrellJ
Dec 23, 2010 02:42 PM
guitar_god2003
Modular V8 (4.6L, 5.4L)
Mar 14, 2010 09:26 AM
snocamo
Dec 10, 2004 07:38 AM
Lifted94XLT
Kansas Chapter
Sep 22, 2004 12:23 AM
the coop
May 13, 2004 12:37 PM
