where is spark plug #3?
Old May 9, 2004 | 12:06 PM
the coop's Avatar
the coop
ok heres my story, did a tune-up about 7 months ago (new plugs,wires etc.)
about 3 months after, it starts misfiring. so i took it to ECHELON FORD in stratford nj who told me it was #3 and the wires. now i cannot understand how this is possible only after 3 months. it gets better---they tell me that they cannot get the spark plug out and they would need to take the entire head off if the plug breaks. i told them i put the plugs in and had no problem when they went in. i think they are trying to get me for some cash. anyway ---can anybody tell me where #3 is on a 99 f150 4.6?
thanks
Old May 9, 2004 | 01:04 PM
TexFinn's Avatar
TexFinn
Thumbs up
3rd from the front on the passenger side.
TS
Old May 10, 2004 | 11:16 PM
03f150man's Avatar
03f150man
someone like racerguy would be a better source but i suggest you soak the plug well with penetrating oil, take it real slow and pull the plug. since it's beeen just 7 months, the plug has not corroded. Maybe they have reason to think the #3 plug was cross threaded or ? if plug went in straight just 7 months ago, it ought to come out easy
Old May 11, 2004 | 08:16 AM
the coop's Avatar
the coop
Thank You!
Old May 12, 2004 | 12:41 AM
Racerguy's Avatar
Racerguy
Any luck yet?
I would maybe try removing the plug carefully but if it wont turn easily I would stop until you're ready to tear it apart just in case it doesn't come out.
Old May 13, 2004 | 12:37 PM
F250Wildman's Avatar
F250Wildman
You possiblely over torqued and stretched the thread causing it to strip out backing it out. Alumunin theads will stetch if over torgued. seen it many times in a machine shop.
