Bad Spark Plug?
Old Sep 20, 2004 | 09:12 AM
Lifted94XLT's Avatar
Lifted94XLT
Bad Spark Plug?
Last night, I pulled off of K10 onto 435 and when I hit about 2grand, Slider started puttering REAL bad and lost All power, it sounds like a bad spark plug in one of the cylinders, b/c it sounded like it was missing or something, but as soon as I hit the gas more, above about 2300, it was back to normal and fine??
Sound like a bad spark plug to y'all?
--Ryan
Old Sep 20, 2004 | 08:17 PM
fordnut1985's Avatar
fordnut1985
did it only do it that one time, or is it doing it regularly (sp)
Duane
Southeast Kansas Coordinator
www.fordtoberfest.com
Old Sep 20, 2004 | 10:11 PM
Lifted94XLT
well, today, it hasn't done it yet at all.... its very odd actually.... so so far, just that one time.
Old Sep 20, 2004 | 10:19 PM
wombodtranger's Avatar
wombodtranger
you might got have got a little water on the plug or oil
Old Sep 20, 2004 | 10:25 PM
fordnut1985
I wouldn't worry about it unless it does it again, then you can start searching. Cars "fart" every once and awhile, nothing to worry about it unless it keeps going
Duane
Old Sep 20, 2004 | 11:13 PM
Lifted94XLT
yeah, very true, I just got worried, b/c all of a sudden, and list is poppin up of stuff that's goin wrong with her.
Old Sep 20, 2004 | 11:51 PM
stlthf1's Avatar
stlthf1
I'm not sure on what engine and all your truck has but a bad coil will do things like that. A bad distributor cap will also do that. If it was a plug I would thing more along the wires. If it was arching onto the manifold or something it would miss.
If it happens again those would be things to look into.
A clogged fuel filter or failing fuel pump would give you some of those symtoms. You'd be shocked at what kind of crap an engine will do when starved for fuel.
Jon
Old Sep 21, 2004 | 12:05 AM
Lifted94XLT
its a 4.0 L V6 OHV with 104K miles on it.... I hope it doesn't happen again. but you never know
Old Sep 21, 2004 | 06:19 AM
Peties3's Avatar
Peties3
If I remember right, you have individual coils for your spark plugs. It sounds to me like one of them is going south.
Mark
Old Sep 21, 2004 | 06:44 PM
fordnut1985
Either that or the TPS has a dead spot.
Duane
Old Sep 22, 2004 | 12:23 AM
Lifted94XLT
two days now, and no problems whatsoever..... I"m guessing its over with
