E4od overdrive and reverse gone and came back
Old Apr 8, 2025 | 06:05 PM
Sidrock66's Avatar
Sidrock66
1st Gear
Hey yall hadnt been on in a while. The truck im working on is a 1996 f250 4x4 5.8L 351w. Reverse started having trouble catching. Then one day is was just gone. Overdrive also. Then miraculously OD came back for one trip? Im just trying to see if there is any possibility that the clutches arent gone? Any other problems it might be?
Old Apr 8, 2025 | 06:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is possible that the feedbolts have loosened. You can check these by dropping the pan and the main valve body. If the feedbolts are tight, the direct clutch has a problem.
Old Apr 8, 2025 | 06:53 PM
Daniel S Brock's Avatar
Daniel S Brock
thanks man ill check that out. I accidentally posted this from the backup account i use here. Couple details i left out 1st through 3rd is all hard shifts now and the transmission also drops to 2nd gear when i turn OD off.
Old Apr 8, 2025 | 06:54 PM
Daniel S Brock
What is the direct clutch?
Old Apr 8, 2025 | 08:38 PM
Mark Kovalsky
The direct clutch is used to create reverse, third, and overdrive ratios.
David1992
Apr 20, 2024 04:39 PM
TXMike06
Sep 18, 2013 07:33 PM
Mark 42
Dec 15, 2006 05:09 PM
kameronth
Jul 11, 2004 02:18 PM
enos
Jul 7, 2003 08:16 PM
