Sponsored by: Auxito
Throttle body
Old Apr 4, 2025 | 08:55 PM
Big Horn 2's Avatar
Big Horn 2
Throttle body
Greetings,
I have a 2002 F150 4.2 with 265,000 on the clock. It’s not licensed and I only drove it around the farm for firewood.
It sits for great lengths. It wouldn’t start. I disconnected the fuel line and put it in a plastic bottle. It pumps good fuel with the key is turned on.
If I disconnect air intake to the throttle body, and pour some gas in it, and reconnect the air intake, it will fire right up until starving itself of the force fed fuel.
I’ve never messed with a throttle body before. If I remove it, is there something I can clean up on it, blow out passages, or something else to get in running?
I’ve thought about scrapping out the truck but it’s nice to just have a beater on the property.
Advice is welcome. I’m always working on my F350 and 7.3 power stroke and thought maybe you all could help out. Thanks!
Old Apr 4, 2025 | 10:09 PM
BareBonesXL's Avatar
BareBonesXL
It wouldn't be a throttle body problem. The TB just controls air flow, the fuel injectors control fuel (gasoline) flow.
Is the THEFT light flashing? As I understand things the PATS (anti-theft) system on these years shut off fuel injection to stop theft. I don't know if they stop spark or not. But, either way, if the THEFT light is flashing the engine won't start. That would be the first thing to confirm.
Beside that, when it "doesn't start" do you mean it doesn't even give a pop or two? Completely dead? Or it catches a few times but won't stay running. You saw fuel flow but did not measure fuel pressure. The system needs around 35-40 psi to work right.
The 4.2 uses a really simple old early fuel injection system. It should be fixable.
Old Apr 4, 2025 | 10:32 PM
Big Horn 2's Avatar
Big Horn 2
Right, no pop or anything. It acts like when a fuel pump is bad……I’ve replaced them on chevy 1/2 ton W/T in the tank.
No, I haven’t put a fuel pressure gage on it but fuel stream is forceful. Fills the plastic soda bottle fast!
The truck was running when I shut it off last before this issue. I know I have rodent damage so who knows.
ill check dash lights for “anti theft”
TY!
Old Apr 5, 2025 | 06:02 AM
RLXXI's Avatar
RLXXI
Fix THAT first, then come back if you still have issues.
Old Apr 5, 2025 | 08:11 AM
manicmechanic007's Avatar
manicmechanic007
Buy a cheap scan tool online and scan it
Test the fuel quality
Make sure you can burn a house down with the stuff
Letting the truck sit is a considerable detriment
Consider driving it once a week at least or you will constantly have problems
Make sure the battery has aove 12 volts when you do try to start it
Repeated cranking will fire the injectors and fowl the spark plugs
Consider replacing the spark plugs and see how wet with fuel (or not) the old ones are
05truckguy
2004 - 2008 F150
34
Feb 19, 2011 12:40 PM
dirtmonkey11
Jan 31, 2010 05:38 PM
JakeTheSnake
Sep 7, 2006 02:51 AM
JAYW
1997 - 2003 F150
Feb 23, 2005 04:59 PM
