throttle body spacer
Old Jul 17, 2006 | 05:14 PM
JakeTheSnake's Avatar
JakeTheSnake
are throttle body spacers any good or are they just a waste of time
Old Jul 17, 2006 | 08:19 PM
Blurry94's Avatar
Blurry94
Nothing more than an expensive paper weight.
Old Jul 18, 2006 | 10:23 PM
X-Hibition's Avatar
X-Hibition
Not a waste of time, but a definite waste of money. The anodized aluminum looks nice, but I never saved any fuel. And I did it on two vehicles.
Old Jul 21, 2006 | 07:02 PM
natewill's Avatar
natewill
I've always been under the impression that they're good if you have already added a bigger throttle body, high-flow intake manifold, cold air intake, etc. But, no, don't waste your money if you are really trying to squeeze a few more ponies from an OEM engine.
Old Sep 6, 2006 | 03:51 PM
Lonewolftx's Avatar
Lonewolftx
Thumbs down Crap . . .
Worthless at Best! It is a really modification!
Old Sep 7, 2006 | 02:51 AM
pud's Avatar
pud
phenolic spacer, goes between the upper and lower intake. A TB spacer only really increases plenum volume, (the area where the runners suck air from) which is already plenty large and will do nothing worthwhile. A phenolic spacer that lengthens the runners will do 2 things: 1) reduce heat on your upper intake, in turn providing cooler air charge. 2) I already said lengthens the runners, which increases airflow velocity (momentum). Longer runners make torque lower down in the rpm band, where shorter ones make the power in the higher rpm ranges.
that said, a TB spacer is something that spawned from carb spacers, which work, onto TBI chevs...since they use an intake like a carbed engine. So since chevy guys were buying the stuff, the bean counters making the parts decided to make them for other companies/styles. So dont waste your money.
