SPE Fuel Filter System
Old Apr 6, 2025 | 09:48 AM
  #46
speakerfritz's Avatar
speakerfritz
Originally Posted by Superdave71
Coalescing filters can be easily overcome by water, that’s their biggest drawback. It’s a matter of scale I suppose. When a fleet terminal has a tanker of fuel delivered, the filters on their pumps could be overcome many times over just by a single instance of water. That’s why they buy drums of emulsifiers or similar acting encapsulating chemicals. It’s the only possible method.
On our trucks, there is no need to pass water. The coalescing filters are effective, the WIF indicator just needs to be adhered to.
The original question I was asking was, I wonder if any of the additives over time, or even fuel compromises the coalescing ‘treatment’ of the pleated filter? You could pull a clean looking filter, that possibly has lost its ability to trap water. That is the reason I’m going to choose to follow the advice of the 900,000 mile RV delivery guy who changes his fuel filters every oil change.
sounds like a good plan to me.
Old Apr 6, 2025 | 01:31 PM
  #47
Overkill2's Avatar
Overkill2
To your original question, no idea... I do admit it's a good question.
Understand your point of view completely... You have to do what you feel comfortable with. But water control is one function of an additive. I also use mine for extra lubricity, anti-gel in cold weather, adds a very modest level of cetane 1.5 to 2 points (that's why I started using Pittsburgh Power's Flashpoint for more cetane and it's very similar in function to K100), puts back alphaltenes back into solution which prevents plugging up of filters -- it would turn a filter very dark brown to black looking and fuel stabilizer (will freshen up fuel if it's old. Truth be told though, control the water and you will prevent any microbes from growing inside fuel, especially on trucks that sit a lot.
Being in a cold winter weather area, when I come home from work or being out, the fuel returned is warm and my tank is not always full. I do not think that there has never been zero moisture in my fuel due to the fuel tank walls and fuel being warm, with the cold air contacting the tank, once I park and shut the truck off. But I get that folks have different opinions and I respect it. All I do is share information for folks to look at to either disregard or look into... that is all.
But that will be the next subject I look into... additive effects on the Coalescing media.
Old Apr 7, 2025 | 06:58 AM
  #48
rufushusky's Avatar
rufushusky
Originally Posted by acdii
Looking at the SPE system, the water trap is on TOP, not the bottom, so how does it trap water? The after markets do not have that hydrophobic screen that blocks free water like the OEM has, the OEM is actually a dual filter system to block both free water and emulsified. The aftermarket would need a filter that can do both. Has anyone cut open one of the water seperators and look at whats in it? Curious if they contain the fine mesh hydrophobic screen.
The 256-8753 has a a drain on the bottom of the filter:
Outside of FASS and their swelling media, most have a drain of some flavor. SPE then puts the port for the WIF post water separator. Fleece and Fass do a better job with the pigtail to have the WIF at the bottom of the water separator.
Old Apr 7, 2025 | 07:16 AM
  #49
rufushusky's Avatar
rufushusky
Has anybody watched the S&S video of the DCR on their development truck that had an aftermarket fuel system? There was no WIF sensor and they ran the DCR unknowingly with water sitting in the filters. The filters rusted and caused lots secondary issues. The S&S tech noted that a benefit of the stock system that doesn’t get mentioned is the plastic filters dont rust.
IIRC that truck was running a Fass fuel system (external pump and filter set up), not exactly a resounding endorsement of Fass' filters. Bypassing the WIF is just asking for trouble IMHO.
Billions of miles and millions of engine hours are put on metal can filters every year, even the most knuckle dragging of maintenance on them your fine. If anyone is going to have issues with rust in the fuel system, the Company I work for should. We have a dozens of loaders, dozers and a few excavators at our terminals that live next to the ocean and on top of a salt pile. When a vessel is in port we have to put them in the holds to scrap it empty.
Pretty much all of them are spin on metal can filters, rarely have fuel system issues. It is a mostly cat fleet, handful of Komatsu here and there but mostly Cat. Rusting out body panels, dime a dozen but the fuel systems hold up well generally speaking.
Old Apr 7, 2025 | 01:14 PM
  #50
acdii's Avatar
acdii
Drained of fuel the OEM filter still weighs about 2 pounds more than in the package, so its trapping something in it.
Old Apr 14, 2025 | 12:37 PM
  #51
demaris's Avatar
demaris
Trailering
deleted. didn't post where wished
Last edited by demaris; Apr 14, 2025 at 12:43 PM. Reason: apparently didn't post where i wanted it to
Old Apr 14, 2025 | 12:46 PM
  #52
demaris's Avatar
demaris
Trailering
Originally Posted by speakerfritz
I was going to post a pro about aftermarket systems but held off…but since you brought up a water concern….since the oem systems have inferior water removal…as evident by the failed fuel pumps that are attributed to water damage…your concern is valid.
I left my stock filters in place and instead added a 1-14 filter manifold and have a Baldwin filter installed between the stock filters..on more than one occasion I drained water out of the add in filter and no water was in the ford stock filters….so proof to me that the stock filter doesn’t remove water very well. I think part of the reason why is becuase the stock ford filter is a pleaded element that is chemically treated to trap water….i think fuel additives break down the chemical treatment. Aftermarket filters are spun fiber media not relying on chemical treatments.
do you have a pic of your install. sounds interesting
Old Apr 19, 2025 | 09:27 AM
  #53
dornjmd's Avatar
dornjmd
I was hoping I was done and had my mind made up. I'm trying to verify the filter efficacy between the donaldson and the OEM.
Donaldson P551000 reads FUEL FILTER, WATER SEPARATOR SPIN-ON -
Efficiency 99% 10 micron
Efficiency Test Std SAE J1488, J1985
Emulsified H2O Efficiency 96 Percent
Donaldson
P551311 reads FUEL FILTER, SPIN-ON SECONDARY
Efficiency 99.9% 5 micron
Efficiency Test Std ISO 19438
OEM reads (please double check my part numbers because my VIN isn't in the system yet so I can't do a specific search yet)
Fuel Filter Element FD4647 (PC3Z9N184C)
I CAN'T FIND SPECIFICATIONS ON THE OEM PARTS?!? What gives?!
Old Apr 19, 2025 | 09:34 AM
  #54
speakerfritz
https://parts.ford.com/content/dam/f...el_Filters.pdf
Old Apr 19, 2025 | 09:40 AM
  #55
rufushusky's Avatar
rufushusky
Ford, as most OEMs are fairly opaque with specs, there was a flyer for the 11-16 filter kit that the upper filter was 5.1 micron at 98% and the lower filter was 95% at stripping water but doesn't specify it is emulisifed or free. Donaldson is probably the most transparent filter manufacturer.
Old Apr 19, 2025 | 09:48 AM
  #56
dornjmd's Avatar
dornjmd
that makes me feel a little better because I’m usually pretty good at finding this info.
what I’m hearing is Donaldson is at least as good, plus it’s easier to drain, and you can set it up to see how much water is there.
sounds like if water is a worry this is at least as good as factory if not significantly better.
Old Apr 19, 2025 | 11:43 AM
  #57
Overkill2's Avatar
Overkill2
Funny you mentioned Donaldson because I was looking at using their version of MC FD4615 fuel filter set and when i emailed them, they stated their lower (DFCM) filter did not have the water separator media in their filter.
I don't look at their filters any different though but do use their P502503 oil filter. I'm sure their can filters are very good.
Old Apr 19, 2025 | 12:56 PM
  #58
acdii's Avatar
acdii
The 17+ fuel water separator is far better working than the 11-16 one. I wish Ford would release a PDF on how it works as a unit and what its specs actually are. I know Ford doesn't want aftermarket to replace their designs, and it probably why it is held back, but knowing if its as goo if not better than anything you can spin on would be good to know since the potential damage that can happen if what replaces it is not as good. I question the water bowl on the SPE as to where does it come into play compared to the stock system? We know the stock system collects ware in the bottom of the chamber, but, how? Prefilter? From the filter? Is emulsified water demulsified by the filter and thats what collects? I know the white screen in the pickup side does not allow water to pass through unless its actually laying IN water to where fuel cannot pass without sucking in water, and if thats the case, having a half gallon of water in that mean you have several gallons in you tank, nothing will stop water from getting through at that point.
The water bowl on the SPE looks to be between filters, or is that leading into the water filter, so seeing how the chambers pass fuel would be quite helpful. So the big question remains for me, is it any better at trapping water than the stock system, and most importantly, why? Before plopping $800 down, what does it do better and can you prove it?
Old Apr 19, 2025 | 01:56 PM
  #59
rufushusky's Avatar
rufushusky
The fs1000 cross references where bench marked on Cummins OTR 10L+ engines and need to be at least 95% efficient at emulisifed water to meet the factory spec. They are very good, I ran a fleetguard FS1000 on my old CR Cummins with great luck.
It's good they told you, less than ideal they lack it.
Based on what I have read the 256-xxxx Cat water seperator is pre-WIF sensor basin or at least I think that is what that little chamber is supposed to be. Fleece and Fass have a better set up using a Donaldson passive WIF on a pigtail than SPEs design IMHO.
Old Apr 19, 2025 | 03:11 PM
  #60
Overkill2's Avatar
Overkill2
There had to be a reason they went to a bigger primary filter and I'm thinking for more water separating media, because of the larger panel filter (more area) for more media and for more water storage at the bottom of the filter -- bigger housing...
Don't know how the new primary panel fuel filter works but has to be similar I would think, but I'm thinking the fuel in my DFCM filter comes through the center, hits the water separating media in the inside there in the center so water can drop out and go down in the bottom where the WIF sensor is, then go through the filter media to the outside and then out of the primary pump housing (DFCM).
But I'm just surmising here and could be wrong... those panel filters are nice as they have a whole lot more media than my primary filter does... hence why one day, after retiring from the job, my truck will have my AirDog pump in the mix. I'll it feed my DFCM from a Titan 50 gal tank with a Fleece Performance fuel pickup... but I digress.
