Guysssss so I’m in some trouble today I got around to messing with FORScan for my 2020 f250 6.7 XL STX and now my truck won’t come out of park for some of reason I’m not sure on why??most of what I messed with was for the power auto fold mirrors spot light bliss blind spot detection didn’t do no coding or anything like that most was the enable and disable part now truck will turn on break lights work steering wheel won’t be locked everything works as it should didn’t mess with tcm or anything and now it just won’t come out of park … one thing I messed up on I thought I save the original files on everything I changed but I didn’t so now I’m not sure on what I changed that’s causing the truck to not come out of park..I did try to mess with pats but unfortunately the scanner I had wasn’t able to work with pats so I’m sure it’s nothing to do with that. HELP!!
Worst case scenario I think you can go to a Ford/Motorcraft web page and download your trucks original configuration. I don’t know where it is but I’m sure someone here knows.
problem solved, saved the codes from as built like @ZooDad mentioned and went to the bcm model and went to the as built data and there were quite a bit of different codes that I restored to its original files and when I got done turned the truck on and now it comes out of park so I must have enabled or disabled something I wasn’t supposed to…I didn’t think it would mess with anything do to I wasn’t writing anything on the as built data I was only messaging with the configuration non as built but I was wrong haha I’m glad it’s fixed though.
