Engine Temperature Display
Old Nov 2, 2024 | 11:42 AM
dnoel's Avatar
dnoel
2024 F350 Diesel
I have the detailed display on for my gauges.
Now that it’s gotten colder outside, the engine temperature starts at 86 degrees and I know it’s colder. I don’t remember my 2017 being this way. Anyone else see this?
Old Nov 2, 2024 | 12:21 PM
bpounds's Avatar
bpounds
We have the 7.3, but yes my coolant temperature also does this. Not sure if it is exactly 86° but that sounds about right. Obvious thing to me was that the oil temp would always be lower and seem to be closer to actual ambient temp. After an overnight soak they should be near exactly the same. But they never are, and ECT is always higher than it could possibly be.
I've decided that I don't care, and now that someone else says they see the same, I'm even less concerned.
Old Nov 2, 2024 | 03:27 PM
drew999999's Avatar
drew999999
Originally Posted by dnoel
2024 F350 Diesel
I noticed this over the past couple of colder days with my temps. Coolant shows 86 degrees at first startup and oil was same as outdoor temp. Wonder if the gauge doesn’t read lower than that but such a strange number to pick. Must be normal.
Old Nov 2, 2024 | 04:10 PM
bpounds's Avatar
bpounds
86°F is exactly 30°C
Old Nov 2, 2024 | 04:36 PM
drew999999's Avatar
drew999999
Nice catch!
Old Nov 2, 2024 | 04:40 PM
BPTS's Avatar
BPTS
Maybe the guy who dreamed up 86 got kicked out?
Old Nov 2, 2024 | 05:32 PM
bpounds's Avatar
bpounds
Yeah, I think they just work in all metric.
Question is, why did they choose to not show actual coolant temps below 30°C? And why only ECT but not EOT or Trans? Just Ford being Ford I suppose.
I don't believe that the sensor does not work below 86/30. For whatever reason they just chose to not show us the actual value.
Old Nov 2, 2024 | 05:38 PM
Strider250's Avatar
Strider250
My 23 shows the actual temp on startup, I just checked it reads 56 and it is 54 outside. The transmission does not, even if it is hot it always starts at 46.
Old Mar 29, 2025 | 11:45 PM
lawdot74's Avatar
lawdot74
4th Gear
Mine also reads 86*F regardless.
actual temp would be nice to see what the block heater is actually doing.
Old Mar 30, 2025 | 07:07 AM
speakerfritz's Avatar
speakerfritz
not getting it....if it is 40F outside....should all temp guages show 40f before startup.....why is 86f (30C) ok?
Old Mar 30, 2025 | 11:28 AM
bpounds's Avatar
bpounds
Just saying that Ford chose to program the computer to not show us coolant temps below 86°F/30°C. None of the temps displayed on recent Ford vehicles are actually values direct from the sensor. They all go through the computers and Ford shows us what they want us to see. Buffered values is another way to say it.
I cannot explain WHY Ford chose to not show us coolant temp below that value. I think we can all agree it is an odd thing to do.
Old Mar 30, 2025 | 08:20 PM
2021F350's Avatar
2021F350
On my 2021 F350 6.2 gas, the coolant temps shown at start up, are the temps that were recorded on at shut down... For the 1st second... THEN, when the ECU gets next reading of the coolant temps, the temperature drops to what ever the ambient temps were over night, and at about 1 second later or so after start up, it shows the lower coolant temps that the coolant is actually at, on 1st start up and the temperature of the coolant goes up about 1 degree every second...
EDIT; This happens even when I don't actually start the vehicle, the temperature # first shown is what the last temperature was when shut down, then, 1 to 2 seconds later, the temperature # changes to the ambient temperature that the coolant is at that moment...
lkbrow1
2023+ Super Duty
Feb 26, 2024 01:15 PM
marker223
Apr 21, 2023 04:53 PM
finnf250
Jun 26, 2019 09:53 AM
tphoenix
Bronco II
Aug 8, 2004 09:13 AM
