Dummy plug
Old Mar 25, 2025 | 12:46 PM
CR172's Avatar
CR172
Dummy plug
Is there a "dummy" 7 pin plug you can plug in so the truck "thinks" it has a trailer attached?
Old Mar 25, 2025 | 01:05 PM
Antonm23's Avatar
Antonm23
Sorta, but its not cheap (see amazon link below).
Amazon Amazon
Old Mar 26, 2025 | 09:29 AM
HRTKD's Avatar
HRTKD
Maybe this one?
Amazon Amazon
The links in this post and the post above aren't working for me. If they aren't working for you, search Amazon with "Trailer light tester". Most of them are less than $10.
Old Mar 27, 2025 | 07:20 AM
SpencerPJ's Avatar
SpencerPJ
If your intention is to eliminate the auto start / stop, there are better ways to do it.
Edit: my mistake, I did not realize the OP had a superduty with 6.7
Old Mar 27, 2025 | 11:38 AM
CR172's Avatar
CR172
Hmmm. I was unaware that the 6.7L Power Stroke had that stoopid feature.......
Old Mar 27, 2025 | 11:55 AM
Antonm23's Avatar
Antonm23
Originally Posted by HRTKD
Maybe this one?
https://www.amazon.com/WUSHIXAN-Trai.../dp/B0CKF6PD4R
I have one of those cheap light testers too, the factory trailer brake controller in the F250 doesn't recognize a trailer as being back there with just the light tester installed (cluster still say "no trailer connected".
But with the more expensive break tester thing installed, it does.
Old Mar 27, 2025 | 02:20 PM
CR172's Avatar
CR172
Good to know. Thanks
Old Mar 27, 2025 | 05:48 PM
HRTKD's Avatar
HRTKD
Thanks for the update. I wasn't sure if it would work or not. Now I'm curious what it takes to make the truck think there's something there. Probably just a resistor but that's the extent of my knowledge.
HRTKD
All Things Towing
Jan 31, 2022 04:45 PM
Gunnerboy
Mar 27, 2017 12:32 PM
Smokeispower
All Things Towing
Mar 14, 2014 11:24 AM
DaveandJennyP
Aug 30, 2009 09:30 AM
jmcder53
All Things Towing
Jun 14, 2008 06:57 PM
