Clean 7 Pin Plug?
Old Jan 29, 2022 | 10:34 AM
HRTKD's Avatar
HRTKD
Clean 7 Pin Plug?
I've used CRC Electronic Cleaner to clean out the 7 pin plug, but the leads are still fairly discolored. Is there any way to clean the leads better? I thought about trying to get some sandpaper in the holes. Will taking apart the entire plug give me complete access to the leads?
Old Jan 30, 2022 | 12:04 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Depends on whether or not is is a molded plug or a partially-molded plug.
Old Jan 30, 2022 | 07:28 AM
SpencerPJ's Avatar
SpencerPJ
I have a nice spark plug cleaner that has a nice small round stiff brush. Works nicely. As far as my truck plug, I've been putting dielectric grease in it, seems to be keeping it very clean.
Old Jan 30, 2022 | 09:08 AM
RV_Tech's Avatar
RV_Tech
There are small brushes for sale on Amazon that can be used to clean the seven pin plug. I actually own one although I have never used it.
Old Jan 30, 2022 | 09:44 AM
dustyroad's Avatar
dustyroad
Buy some deoxit, little pricey but worth it especially if you plan on cleaning up electric contacts.
The spray does a good job of cleaning up the contacts and allows the deoxit to really do its job.
I also have a terminal maintenance kit made by IPA. part#8048
It is nice but there have been some nasty terminals where I still needed to get some sandpaper in there.
Old Jan 30, 2022 | 10:05 AM
HRTKD's Avatar
HRTKD
Thanks for the suggestions folks. I'll clean it up once I finish the inside-the-trailer project.
Old Jan 31, 2022 | 06:18 AM
Pugga's Avatar
Pugga
If you roll sand paper, you can get in there, or roll it around a small pick for some rigidity.
Old Jan 31, 2022 | 03:51 PM
Mike_in_STL's Avatar
Mike_in_STL
Emory file, cheap and flexible, beauty section at the walls - mart. Or "borrow" one from the Mrs. they're made of stiff paper and can be trimmed to fit. Just need to take the oxidation off.
Old Jan 31, 2022 | 04:45 PM
dustyroad's Avatar
dustyroad
every toolbox should have a nail file in it.
did it for years, buying that kit was like a new world maybe it was just a new tool/toy but it does seem easier. You can also buy a lifetime supply of nail files for the cost of that kit
They wear down/out and need replaced also. But wow night and day. I'm sold on it since all my vehicles are antiques and I already used mine several times.
Smokeispower
All Things Towing
Mar 14, 2014 11:24 AM
BumpJr
Modular V8 (4.6L, 5.4L)
Apr 26, 2013 10:11 AM
RickBraden
All Things Towing
May 19, 2012 06:27 PM
pgjeepster
General Diesel Discussion
Apr 17, 2008 01:05 AM
Captain D
Dec 14, 2007 08:33 PM
