Glow Plug Timing
Old Apr 3, 2025 | 08:56 AM
RacinJasonWV's Avatar
RacinJasonWV
So you’re seeing a consistent 45 second delay between key on and voltage drop?
My understanding is that the PCM controls the
GPR through the small ground wire on the relay as the trigger.
I would remove the ground and test it (positive battery to ground wire) to see if the delay is coming from the PCM. That takes the mechanical aspect of the GPR out of the equation.
Next I would pull the small positive wire from the GPR and make sure it’s always hot when key on (I think that’s the case for that wire).
Old Apr 3, 2025 | 09:32 AM
pvdiag's Avatar
pvdiag
Yes. When it is generally<10F. When >25-30F, it is near instantaneous.
It will be a few days before I'm back home, but by then I think my window of cold temps for testing will have closed.
Old Apr 3, 2025 | 09:54 AM
RacinJasonWV
The PCM makes its decisions based on the EOT sensor correct? Does your sensor read within expected values?
Old Apr 3, 2025 | 10:03 AM
Pikachu's Avatar
Pikachu
IAT and BARO are also factors
Bananasfoster
Feb 28, 2020 09:33 AM
Cjinx
Dec 15, 2017 06:32 AM
LIL-JOE
Nov 12, 2017 02:29 PM
mudracin74
Feb 1, 2007 06:14 PM
Ken aka Savage
Sep 15, 2004 02:01 PM
