Glow Plug Warm Up? - 2019 6.7
I wondered about that as well and also wondered about cold weather furl pump ramp up time.
having found nothing...,,on my push button start ....I wait 5 sec before engaging the brake to start.
until there’s some more clarity on this ...will have to wait and see
in my mind in feel like sometimes I see a glow plug icon light that comes on some times ...so maybe this is happening in the back ground depending on temps.
Just start the truck. The glow plug light (orange coil) is rapid as the PCM controls the rapid heat plugs, they hit 1500 degrees within a second or two. Turning the truck to accessory mode does not activate them. If its truly cold enough the PCM will continue to run them on and off after starting and shut down the piezo injection during very cold starts.
Diesel Engine Fast Start Glow Plug System
The diesel engine glow system consists of:
• Eight glow plugs (one per cylinder)
• Glow Plug Control Module
• Engine Coolant Temperature sensor
• Barometric pressure sensor
• Environmental temperature sensor
The powertrain and glow plug control modules electronically control the glow plug system. After you switch the ignition on, the glow plug control module immediately energizes the glow plugs. The glow plug control module uses the engine coolant temperature, barometric pressure sensor and environmental temperature sensor to determine how long the glow plugs stay energized. The required time for the glow plugs to be energized decreases as the coolant temperature, barometric pressure and environmental temperature increase.
Switch the ignition on. Do not start the engine until the glow-plug indicator turns off.
When the glow plug pre-heat indicator turns off, turn the key to start. After you start the engine, the glow plugs may remain on for a period. If you do not start the engine before the glow plug activation time ends, you will need to reset the glow plugs by switching the ignition off. After the engine starts, allow it to idle for about 15 seconds. This protects the engine. Do not increase engine speed until the oil pressure gauge indicates normal pressure
a lot of 17’s and up have push button to start models
Page 175 of the owners manual has a little more info. All the above is mostly correct. In addition, at very low temps, the throttle will be disabled for 30 seconds to allow engine oil to circulate. Recommendation in the manual is to allow the engine to warm up several minutes if -15 ° F. But definitely a new ballgame with the modern glow plugs. Coming from a 2005 6.0 its night and day.
My truck is a 19 with key start. every morning I get the glow plug icon in the dash. It last for about 2-3 seconds then disappears, so I crank her on up. What I have noticed is if the truck sits for about 3-4 hours I dont get the glow plug icon. Im assuming the engine is warm enough to where the glow plugs dont need to ignite.
My remote start is a different story. some mornings the truck cranks up instantly others there is a 2-3 delay.
I have a 19 with push button. We hit -40° A few times this winter (pick your units as you desire). Foot on the brake, press start. The start will automatically delay if glow plugs are required and then start when they are no longer required.
just saved you an additional button push
