Hello I have a 2008 ford e350 van and heater blows heat only when driving soon as I stop starts blowing cool air when driving it blows hot what could that be possibly issues? Thanks
A broken blend door will flap around and cause intermittent heat then no heat
Pull the actuator and move the blend door manually
I think you'll find yours is broken
If this heat seems to come and go more with the engine speed I'd day it was very likely the heater core has restricted coolant flow through the heater core.
If any sort of "stop leak" or something similar it could be the reason. OP with the engine at full operating temperature feel the heater core inlet and outlet houses near the evaporator housing under the hood, pay attention to how or if their temps rise and fall as the engine is revved up etc.
IMHO if the blend door was the sole fault the temps at the hose ends wouldn't be in sympathy with engine speed.
