Trailer Brake Controller Connector
Old Mar 4, 2025 | 10:15 AM
CalhounMoto's Avatar
CalhounMoto
6th Gear
I have a 2005 Ford F150, XL, 4.6L, 2WD single cab long bed work truck with the standard 4-flat trailer light plug.
I am working on adding a 7 way plug with a trailer brake controller for towing. I purchased the following items from etrailer.com:
https://www.etrailer.com/Accessories...ler/ETBC7.html
https://www.etrailer.com/Trailer-Bra...&hhmodel=F-150
The installation instructions on both seem pretty straightforward, but the trailer brake controller comes with a wiring harness that plugs into a factory plug under the dash. This plug is gray in color, has 4 pins, and it located directly behind my OBD-II port. Every thing I can find on YouTube, forums, and even Curt's website say "just plug the brake controller in with the included adapter and bam! Trailer brakes!". This makes no sense to me as the 7 way plug will still need a 12v wire coming from the battery of the truck, and a wire from the brake controller, ran back to it.
If I have to cut the plug off of the brake controller and manually wire everything in per the instructions on the 7 way conversion kit, I'm alright with that, but then why include a fancy harness?
My main questions are: What is this gray, 4 pin plug? What is it's function? Where do the wires from this plug go? How does plugging the brake controller into it do anything?
Thank you in advance for any assistance yall are able to offer & apologies if I'm just being dumb.
Gray plug location. Passenger side of steering column.
Inside of gray plug
Inside of gray plug
Old Mar 4, 2025 | 10:46 AM
Don Ridley's Avatar
Don Ridley
See the wiring diagram at the bottom of the screen shot.
The 4 wires are
Power...red
Brake signal in...light green
ground....white
Brake signal out...dark blue
A 30 amp fuse, F105, must be installed in the central junction box.
Old Mar 4, 2025 | 10:56 AM
CalhounMoto
6th Gear
What is the connector number in the wiring diagram?
The wires coming out of the gray plug under my dash are black, blue, green & red.
Old Mar 4, 2025 | 11:04 AM
Don Ridley's Avatar
Don Ridley
C2026
GND is black, not white. Sorry.
Old Mar 4, 2025 | 11:05 AM
CalhounMoto
6th Gear
Understood! So where does the other end of these wires on connector C2026 come out? Do you have a diagram of that by chance?
Old Mar 4, 2025 | 11:19 AM
Don Ridley's Avatar
Don Ridley
C136 under the frame somewhere will have the blue brake wire and another wire for trailer battery power. You will have to find this connector to get trailer brakes to your new connector. I would go to Pick an Pull and remove C136. Otherwise you have to splice into the blue wire.
I don't have an F150 but my Econoline van has the same trailer wiring setup
Old Mar 4, 2025 | 11:22 AM
CalhounMoto
6th Gear
Awesome, thank you for the help. Do you know how many pins/wires are in C136 and it's color? That will make it easier to identify.
Thanks,
Old Mar 4, 2025 | 11:34 AM
Don Ridley's Avatar
Don Ridley
Sorry, doing all this on my phone and the small screen is causing me problems.
Connector C411 seems to have the trailer brake and trailer power wires. I can't easily identify all the other wires on C411 but here it is. Pin 9 dark blue is the brake signal.
Old Mar 4, 2025 | 11:58 AM
CalhounMoto
6th Gear
Never mind, I found it. I think I'll just splice my 7-way into those wires. Thanks again for the help!
Old Mar 18, 2025 | 10:26 AM
CalhounMoto
6th Gear
I spliced into the harness & everything seemed to be functioning correctly, but when I hit the brakes, there is about 7 volts sent to the blue wire which the trailer brake controller does not like & throw an error message stating it is overloaded & there is a short to power somewhere. The controller will also randomly show "trailer connected/disconnected" when hooked up and with the truck running, regardless of pressing the brakes. Did you run into this issue with yours?
*edit* I measured the 7 volts when pressing the brake with the trailer brake controller disconnected from the harness while the truck was running. Just checking the blue wire at the connector under the dash, and the brake controller pin on the 7-way in the rear. The other pins on the connector under the dash were ground, battery power for the controller (14.5 with truck running) & the brake switch signal (around 12v with the truck running).
Old Mar 18, 2025 | 04:03 PM
Don Ridley's Avatar
Don Ridley
I don't have any experience with your model year and brake controller. You may have to change a setting in the ECU (or other module) to get the controller working with the rest of the system. But nothing in the wiring diagrams suggest this.
The trailer brakes should come on slowly and peak at a voltage based on the gain setting. You can test this with a 12v light.
Old Mar 20, 2025 | 12:33 PM
torq'ta 5 8's Avatar
torq'ta 5 8
for future reference
2004-2008 f150 wiring schematic - Page 2 - Ford Truck Enthusiasts Forums
Ol' Grouch
All Things Towing
Mar 7, 2024 11:26 AM
jpsheb
Jan 31, 2013 02:44 PM
rocknrod
1997 - 2003 F150
Dec 5, 2012 08:27 PM
DieselBeast01
2004 - 2008 F150
Jan 27, 2012 06:47 AM
BENG0924
Jul 29, 2009 09:28 PM
