Need help with fuel pressure
Old Feb 27, 2025 | 01:31 PM
Redleg68's Avatar
Redleg68
4wd Low
1993 F-150, 5.0 dual tanks. Running low pressure from both tanks, 28 key on, 26 running. Pull vac off pf FPR, stays around the same. Replaced fuel filter, no change.
So, old truck, almost all original, decide on new tanks and pumps (delphi). Starts up, pressure 33 key on , 28 running with vac. Pull vac, 33 key on, 38 no vac. Change FPR, no change whatsoever.
What am I missing? Is there something else that could affect the pressure like this? When I changed the pumps, I changed the inline filter as well.
All started with running too lean and missing at highway speeds, especially in OD
Old Feb 27, 2025 | 02:16 PM
jas88's Avatar
jas88
All started with running too lean and missing at highway speeds, especially in OD.
Is this still going on? If not, perhaps all is good now? You are not way far off on pressure, perhaps your gauge reads a little low?
Old Feb 27, 2025 | 03:00 PM
Conanski's Avatar
Conanski
Yes perhap the gauge is just reading low, can you try another one?
Old Feb 27, 2025 | 05:54 PM
Redleg68's Avatar
Redleg68
4wd Low
I tried another gauge, same results. Truck still bucks/misses when steady speed up an incline.
Old Feb 27, 2025 | 08:00 PM
Conanski's Avatar
Conanski
Does fuel pressure bleed of immediately after engine is shut off? Can you tell of any fuel is finding it way into the other tank?
You definitely have a pressue problem, the fuel either goes into the other tank(crossflow problem) or into the engine(leaky injectors).The second one makes the oil smell of gas and can overfill the crankcase if it's really bad. Replacement fuel delivery modules are supposed to have the check valves to prevent crossflow but some don't and some are poor quality and don't last
Old Feb 28, 2025 | 04:51 AM
manicmechanic007's Avatar
manicmechanic007
Miss under load
Most likely a plug wire or ignition secondary misfire
I'd check the capacitors in your processor
I'd check the cap and rotor and the wireset
Spray some water on those plug wires at night and look for lightning is an easy way to test wires
Old Feb 28, 2025 | 11:51 AM
Redleg68's Avatar
Redleg68
4wd Low
Found ground issues that I fixed and now running like a 32 year old truck should!! Thanks for the input folks
Old Mar 12, 2025 | 01:00 PM
Jtsarby's Avatar
Jtsarby
I am chasing something similar. Where was the ground issue?
calebo10
Jun 8, 2023 07:20 AM
cjben
Aug 30, 2015 11:24 PM
musicars
Oct 27, 2014 03:48 PM
PaulDH
16
May 22, 2010 04:15 PM
codys50ford
1983 - 2012 Ranger & B-Series
May 8, 2008 06:29 PM
