Fuel pressure question
Old Oct 27, 2014 | 02:50 PM
musicars's Avatar
musicars
I'm running some tests to determine what is causing a lean code 172 on my '94 F-250 5.8l. Key on pressure not running is only 20 psi. When checking running fuel pressure I get 32 psi from the front tank and 34 psi at the rear tank. When disconnecting the regulator vacuum line the pressure jumps to 42 psi and 44 psi.
I'm having problems finding the pressure info I need but so far I find one post saying 45 psi is normal running pressure. Could this be a regulator issue? The fuel filter can is pretty rusty so may be original. Can a dirty filter cause this?
Thanks for any info!
Old Oct 27, 2014 | 03:43 PM
subford's Avatar
subford
Fuel pressure at idle is 30-32psi.
Fuel pressure at snap WOT is 40psi.
44psi is too high as it is set up for 39.6psi across the injectors at all times.
45psi is wrong.
Sounds like your gauge may be a little off.
There is no such thing as just a key on pressure as it could be anywhere from zero to the spring pressure of 40psi. 40psi if the key is on with pin #6 of the self-test plug grounded to pin #2 or grounded to the NEG post of the battery.
Old Oct 27, 2014 | 03:48 PM
timbersteel's Avatar
timbersteel
45 psi isn't normal on the V8 versions.
If in doubt about the last fuel filter change, do it 1st. Scratch that problem off the list.
You should see 30-32 psi running, 38-40 with vacuum line disconnected from the FPR. Also, snapping the throttle should show an increase in fuel psi (with vacuum hose connected to FPR).
When you say that you have 20psi, engine off, what will it do if you cycle the key on and off several times? How long does your fuel psi stay at (X) amount when you shut the truck off? How long does it hold (X) amount after it primes? The fuel pump is designed to only prime for 1-2 seconds after the key is rotated to the run position.
OBD_F350
Aug 5, 2019 10:48 AM
XSleeper
Apr 29, 2014 01:42 PM
PaulDH
16
May 22, 2010 04:15 PM
codys50ford
1983 - 2012 Ranger & B-Series
May 8, 2008 06:29 PM
Aerostar1
Aerostar
17
Feb 19, 2007 11:03 PM
