6r80
Old Feb 14, 2025 | 07:08 PM
6r80problems's Avatar
6r80problems
4th Gear
6r80
Hi, new here. Hopefully this wasn't already covered.
Installed new lead frame board, along with new bulk head sleeve and the Rectangular fitting.
Refilled with the transmission fluid.
Let it get up to temperature, roughly 190ish.
Checked and topped off appropriately.
Went to drive it, but it suddenly shifts from 1st to 5th. Then tries to correct itself and goes to 3rd/4th.
Won't shift further down than 2nd, won't go further up than 5th.
Both ***** are lined up properly. Connections are tight. Is there something I may have missed?
Thanks for your help
Old Feb 15, 2025 | 06:33 AM
npccpartsman's Avatar
npccpartsman
What kind of lead frame did you put in? Motorcraft or other?
Old Feb 15, 2025 | 11:45 AM
6r80problems
4th Gear
I got it off amazon.
Old Feb 15, 2025 | 12:06 PM
JKBrad's Avatar
JKBrad
90% of the stiff on Amazon is garbage. And a certain percent of known brand
merchandise is counterfeit. I would only buy from a well recognized seller.
Old Feb 15, 2025 | 12:07 PM
6r80problems
4th Gear
which one would that be?
Old Feb 15, 2025 | 12:47 PM
deserteagle69's Avatar
deserteagle69
Buy from a Ford dealer - either local or on-line. Best way to ensure you are not getting counterfeit parts.
I got burned bad buying on line...bought a set of "Genuine OEM Motorcraft Spark Plugs" that sure appeared to be OEM - all in boxes marked like in any other Motorcraft spark plug, and the markings on the spark plugs appeared genuine. Center electrodes melted away in 2000 miles. Counterfeit repair items are a huge problem right now - lots of YouTube videos about it on line. No just spark plugs but all sorts of repair/replacement stuff. These items may appear to be OEM but are made of inferior materials!
Old Feb 15, 2025 | 01:26 PM
6r80problems
4th Gear
appreciate it, I'll buy oem
Old Feb 16, 2025 | 09:57 AM
GlueGuy's Avatar
GlueGuy
What is it about the lead frame that makes it so fragile?
Old Feb 16, 2025 | 11:40 AM
Angelo7's Avatar
Angelo7
Dirty fluid shorts it out??
Old Feb 16, 2025 | 02:05 PM
JKBrad's Avatar
JKBrad
The best video I've seen on this issue. Make sure when replacing that you use an genuine OEM Ford part, and that it is the latest part number.
lbicknese2005
Mar 19, 2024 06:16 PM
Tesknox
May 7, 2023 05:45 PM
Alabama Style
Apr 5, 2017 01:04 PM
TallGuy_Az
Jul 21, 2006 02:21 PM
kienzlesa@netscape.net
Dec 16, 2003 08:43 PM
