A little backstory I’m trying to find replacement for my PCM. The previous owner had replaced the PCM with the help of others on forum appears to be a cardone reman. I’m unsure if it is correct part # for my truck and I have called ford dealer and tried researching myself for the replacement but everywhere I have asked just says they need the OEM part # off original PCM, which as stated above is not available to me. If anyone on here has access/ or a way to get the proper part # using vin and cal code that would be awesome, or at least point me in direction that I could do so. When I called ford dealer they gave me 8 options using the VIN and said the cal code would not help them narrow it done.
