PCM part #/cal code
Old Feb 13, 2025 | 05:36 PM
piff1392's Avatar
piff1392
PCM part #/cal code
A little backstory I’m trying to find replacement for my PCM. The previous owner had replaced the PCM with the help of others on forum appears to be a cardone reman. I’m unsure if it is correct part # for my truck and I have called ford dealer and tried researching myself for the replacement but everywhere I have asked just says they need the OEM part # off original PCM, which as stated above is not available to me. If anyone on here has access/ or a way to get the proper part # using vin and cal code that would be awesome, or at least point me in direction that I could do so. When I called ford dealer they gave me 8 options using the VIN and said the cal code would not help them narrow it done.
my truck is a 1996 f250 5.8 with e4od
Old Feb 13, 2025 | 05:51 PM
rla2005's Avatar
rla2005
Results from searching on this forum with keyword: 6-76A-R05
Thanks to Subford.
Old Feb 13, 2025 | 06:16 PM
piff1392's Avatar
piff1392
Thanks to Subford.
Roger that so it would F6UF 12A650-N for a replacement if I’m reading that correctly
Old Feb 13, 2025 | 06:53 PM
R&RFord's Avatar
R&RFord
F6UF-12A650-NB is the part number, which matches the cardone unit you have.
F6UF-12A650-N is the engineering number. Ford puts engineering numbers on parts, not part numbers. No idea why.
Old Feb 13, 2025 | 07:20 PM
piff1392's Avatar
piff1392
Got it seems overly confusing but at least now we know the cardone part # matches cal code and vin
Old Feb 13, 2025 | 08:06 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I would say the correct computer was selected based on the calibration code.
Old Feb 14, 2025 | 03:50 AM
piff1392's Avatar
piff1392
more so saying my truck was running on correct computer
Old Feb 14, 2025 | 06:01 AM
manicmechanic007's Avatar
manicmechanic007
The tear tag we used to call it needs to match
That's the actual calibration for the processor
Yours is SSC
Old Feb 14, 2025 | 07:56 AM
AuroraGirl's Avatar
AuroraGirl
options. mind you , the differences could be minor, some very big. but heres what my source has
Old Feb 14, 2025 | 10:39 AM
piff1392's Avatar
piff1392
Ended up cancelling my flagship one order and getting a refund, pulled the trigger on this one from rock auto
Old Feb 14, 2025 | 10:40 AM
piff1392's Avatar
piff1392
Yours is SSC
Another wrench in the mix
Nedward
Jul 28, 2024 03:07 PM
Calebcuster
Oct 26, 2023 06:34 AM
Drewu223
Jan 8, 2023 04:52 PM
THEDON117
Jul 9, 2021 11:00 AM
diehardstroker
Sep 2, 2013 11:45 PM
