Idle Problems
Old Feb 12, 2025 | 04:38 AM
Aus f150's Avatar
Aus f150
Trailering
Idle Problems
Just when i thought i had the truck sorted and was running reallt well, this is the problem i have now .
Sometimes when i shift from park to a gear be it forward or reverse the idle speeds up then comes down slowly.
Also as it is summer down here when i use the air con the idle speeds up and does not come down.
5.0 EFI V8 and AOD trans.
No codes from the reader and new motorcraft tps switch.
Thanks in advance.
Old Feb 12, 2025 | 08:59 AM
jas88's Avatar
jas88
Clean your IAC valve and reset computer.
Old Feb 12, 2025 | 03:18 PM
Aus f150's Avatar
Aus f150
Trailering
Already cleaned the iac valve and reset the computer . So i will get a new iac this week.
daniel valdivia
Apr 11, 2021 10:58 PM
forddude2134
Dec 2, 2009 07:45 PM
brisk_truck
Jun 6, 2007 02:32 PM
johnstoys2
Apr 28, 2006 07:57 AM
psupoor
Aug 17, 2003 07:28 PM
