Stalling
Old Aug 9, 2003 | 08:33 PM
psupoor's Avatar
psupoor
Question Stalling
I've been running into some trouble with my 92 E250 300 - 6. When I go into reverse the engine abruptly stalls. The idle seems low to begin with....any input would be greatly appreciated.
Old Aug 9, 2003 | 08:58 PM
1987LTDmasta's Avatar
1987LTDmasta
Stalling
my CrownVic was doing this as well. first off your idle is set pretty low. there is an adjustment for base idle right by the throttle body. i never worked on a 300 EFI before so i dont know its exact location. also, your IAC (idle air control) has probably called it quits as well, although this would also cause other problems like fluctuating idle, or very low warmup idle.
Old Aug 17, 2003 | 07:28 PM
psupoor's Avatar
psupoor
Stalling
I was able to boost the idle a bit....that's helped so far...next move is the IAC, Thanks.
jduggan43
Sep 30, 2013 10:29 AM
Old Time Ford
Jun 25, 2009 05:44 AM
vicnation
Jan 14, 2007 02:59 PM
green52
Jan 10, 2005 01:03 AM
