P0281 intermittent
Old Feb 5, 2025 | 08:16 PM
bismic's Avatar
bismic
Hot oil, low rpms.
Could be. Could be stiction also.
One thing that can be done is to swap injectors (edit) 5 and 7 and see if the code moves to the #5 cylinder.
Old Feb 5, 2025 | 08:18 PM
Homerunking2394's Avatar
Homerunking2394
Originally Posted by bismic
Hot oil, low rpms.
One thing that can be done is to swap injectors 2 and 4 and see if the code moves to the #4 cylinder.
ah I didn't use the friction modifier in my oil chnage....is swapping Injectors requiring new o rings etc...?
Old Feb 5, 2025 | 08:20 PM
bismic's Avatar
bismic
Sorry for a "cut and paste" mistake on the previous post. I edited it for the correct injector/cylinder numbers.
It would be wise to change the o-rings. EDIT again - I see in post #1 that there is only 15k on the injectors. You may not need to use new o-rings then.
Also, usually stiction is a cold oil issue though.
Old Feb 5, 2025 | 08:22 PM
Homerunking2394
It would be wise to change the o-rings. I assume the injectors have quite a few miles on them.
Usually stiction is a cold oil issue though.
they have 15k roughly on them
Old Feb 5, 2025 | 08:24 PM
bismic's Avatar
bismic
Where did you get them?
Old Feb 5, 2025 | 08:25 PM
Homerunking2394
they are oem reman....installed by a shop
Old Feb 5, 2025 | 08:29 PM
bismic's Avatar
bismic
If it was a local shop, could you run it by them and see what they say about it? Maybe they would do some troubleshooting and cover it under warranty?
stevegintn
May 24, 2023 07:40 AM
Number21
Feb 8, 2021 08:18 PM
tracyclifton
May 28, 2014 02:29 PM
daddgonemadd
Dec 6, 2009 08:29 PM
tetraruby
Aug 23, 2002 10:14 AM
