P0281 intermittent
Old Feb 5, 2025 | 05:50 PM
Homerunking2394's Avatar
Homerunking2394
P0281 intermittent
My truck began running rough at idle and low rpm once in a while. Replaced ficm due to low ficm voltage which solved that issue. But I still have an issue when once in a while I'll come to a stop and the truck starts running rough and code 0281 pops up. Truck had all new injectors installed about 15k ago
Old Feb 5, 2025 | 06:47 PM
tfunk88's Avatar
tfunk88
Maybe the #7 injector harness plug isn’t fully in?
Old Feb 5, 2025 | 06:49 PM
Homerunking2394
I'm assuming this is under the valve cover?
Old Feb 5, 2025 | 07:04 PM
tfunk88's Avatar
tfunk88
Nope, it’s just outside the intake
Old Feb 5, 2025 | 07:19 PM
Homerunking2394
found it .all looks good
Old Feb 5, 2025 | 07:46 PM
tfunk88's Avatar
tfunk88
Did you unplug it and then make sure to plug it in fully? Sometimes they look…and feel…fully plugged until you pull a bit harder and they’re not
If that’s not it maybe you got a bad injector, or maybe the oil ring on that one is leaking somehow
Old Feb 5, 2025 | 07:48 PM
Homerunking2394
I only looked at it and it looks the same as the others in that bank. What would cause an o ring or the whole injector to fail? Maybe the ficm fried the injector from being low voltage?
Old Feb 5, 2025 | 07:52 PM
tfunk88's Avatar
tfunk88
Ahh, I was thinking the FICM was replaced before injectors. That could’ve done some not good stuff…but also just maybe you got a bad injector
At installation if an injector o-ring was nicked, or if the oil rail nipple o-rings were reused they can leak over time
Old Feb 5, 2025 | 07:56 PM
Homerunking2394
well the whole bulletproof was done by powerstroke specialty in georgia so it looks like then the ficm claimed an injector. Yay.....hope this isn't a time consuming job..truck runs amazing when the injector isn't acting up
Old Feb 5, 2025 | 07:58 PM
tfunk88's Avatar
tfunk88
Hopefully it’s simple. I’d definitely unplug and then plug in the injector just to see
Old Feb 5, 2025 | 08:00 PM
Homerunking2394
I'm new to 6.0 injectors but it looks like there's a metal tab that gets pulled out to release the plug
Old Feb 5, 2025 | 08:08 PM
bismic's Avatar
bismic
Keep in mind it is a contribution code, and not an electrical code.
Old Feb 5, 2025 | 08:09 PM
Homerunking2394
which means mechanical?
Old Feb 5, 2025 | 08:11 PM
bismic's Avatar
bismic
More likely IMO.
You could have a small high pressure oil leak at that injector.
Old Feb 5, 2025 | 08:13 PM
Homerunking2394
More likely IMO.
would that cause it to happen after cruising on the highway and coming to a stop....this is the only time it happens, after a long drive and then coming to a stop....clears up after driving again for 2 to 5 minutes
