Temporary rough idle?
Old May 17, 2014 | 11:04 PM
Number21's Avatar
Number21
I have an 04 F350 with almost 200k. Just had the low and high pressure oil pumps replaced, and IPR rebuilt. Mechanic also checked a lot of other stuff. Truck is running nice, except every once in a while when I let off the throttle it idles really rough. Almost chugging. If I shut the truck down and restart, it goes away. Sometimes it goes away on it's own.
Only seems to happen sporadically, and only when it is hot. I had a bit of cold stiction with my injectors prior to fixing my FICM, and this feels different than that. Any idea what's causing this?
Old May 17, 2014 | 11:32 PM
04badford's Avatar
04badford
Check the ICPV, you will get wack values , stalling , surging, bucking. unplug the connection from ICP and see if it goes away.
Old May 18, 2014 | 12:09 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Just dealt with a similar condition on a friend's truck. It was a dying injector only found using a contribution balance.
Josh
Old Feb 8, 2021 | 06:41 PM
04f350-04excursion's Avatar
04f350-04excursion
Fix?
Did you ever come up with a fix?
Old Feb 8, 2021 | 08:18 PM
LindenBruce's Avatar
LindenBruce
From nearly 7 years ago? B.
2006powerstroke90
Apr 22, 2017 05:45 PM
95schauf
Mar 2, 2013 09:39 AM
rodneywar
Aug 3, 2009 10:53 PM
jyblood
Dec 30, 2008 08:35 AM
