E40D giving me issues
Old Feb 3, 2025 | 09:04 AM
brockxx03's Avatar
brockxx03
5th Gear
Exclamation E40D giving me issues
Hello all! Hoping somebody can give me a direction on what to try next. I have a 94' F-250 7.3 turbo idi. I've owned the truck for about a year now and haven't gotten anywhere with it. Previous owner had a shop put a new transmission in and didn't seem to fix his (now mine lol) issue. Its slamming into gear, weird down shifts, acts like it doesn't know where its at. Accelerating it will go 1-3-2-3-4. Everything i've replaced on the truck regarding the transmission issue are the VSS sensor, transmission range sensor/neutral switch, tach sensor, swapped PSOM module out of another truck, sent gauge cluster out to get rebuilt. Took truck to a transmission shop, the told me everything is mechanically sound. Somedays the truck will drive 'okay', somedays perfect, and somedays not pleasant.
Current Codes
23- Throttle position sensor signal out of range, Fuel injector pump level sensor out of self test range
29- Insufficient input from VSS, Insufficient input from PSOM
65- Overdrive cancel switch not changing state; transmission fault
74- Brake On/Off switch fault; not actuated
So thats where i'm at with it. These codes are kind of leading me to believe its a computer issue, but wanted to get a second opinion on where im at with it. Thanks!
Old Feb 3, 2025 | 10:22 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When you ran self test with the engine off, did you hold the accelerator pedal to the floor? If not, you'll set a code 23.
When you ran self test with the engine off, did you press the OD OFF button? If not, you'll set a code 65.
When you ran self test with the engine off, did you press the brake pedal? If not, you'll set a code 74.
Code 29 is your problem. The PCM is getting erratic vehicle speed info. That's why it is shifting erratically. It's either a bad PSM (yes, I saw that you swapped it,) a bad VSS (I saw you swapped that, too,) or a damaged wire between the VSS and the PSOM or between the PSOM and the PCM.
Old Feb 3, 2025 | 10:42 AM
brockxx03's Avatar
brockxx03
5th Gear
Hi Mark! When I did the testing for the codes I did both key on, engine off and key on, engine off. When engine off, I got codes 23 and 29, with engine on I got codes 65 and 74. Only during the engine on test is where I pushed accelerator, rotated steering wheel, pushed brake, and turned off overdrive. I did not put accelerator to the floor, just half way. I retest with the engine off and try all of what you said and ill update you, thanks.
Old Feb 3, 2025 | 11:02 AM
brockxx03's Avatar
brockxx03
5th Gear
After retesting, 65 and 74 went away. 23 and 29 still remain.
Old Feb 3, 2025 | 12:11 PM
Mark Kovalsky
Then you may have a FIPL problem along with the vehicle speed problem. The FIPL (fuel injection position level) is located on the injection pump. They were a known failure item.
Old Feb 3, 2025 | 12:13 PM
brockxx03's Avatar
brockxx03
5th Gear
When code states "sensor out of self test range" could that be a insufficient voltage?
Thanks for the reply
Old Feb 3, 2025 | 12:39 PM
Mark Kovalsky
The PCM should see full throttle voltage at the sensor during self test. It didn't see that.
Old Feb 3, 2025 | 12:49 PM
brockxx03's Avatar
brockxx03
5th Gear
understood, thank you
Tom D
64
Nov 24, 2025 06:17 PM
vintagequest
Jan 20, 2016 05:02 AM
lightning.fast.svt
17
May 21, 2015 01:01 PM
lakewood
Apr 25, 2013 09:59 AM
armantanzarian
1983 - 2012 Ranger & B-Series
May 5, 2006 09:16 AM
