Replacement Speedometer Cable Question
Old Jan 29, 2025 | 11:22 AM
75over77 F100's Avatar
75over77 F100
I have a question about a new speedometer cable.
I have cleaned and lubed my current speedo cable and still have a bouncing speedo needle so I am replacing the cable. The new cable came in but I noticed that it does not appear to be lubricated at all. The below is all that the service manual mentions about lube:
“Lubricate the cable core exposed at the transmission ferrule with B5AZ1958I-A lubricant or equivalent. Apply a coating of ESA-MIC45-A or equivalent to the O-ring on the ferrule.”
Do I not need to lube the entire new cable before installation?
Old Jan 29, 2025 | 02:18 PM
mark a.'s Avatar
mark a.
Your problem is more likely in the spedo head and not the cable.
Old Jan 29, 2025 | 03:12 PM
TheGreatPumpkin's Avatar
TheGreatPumpkin
I replaced mine like 2 weeks ago, no instructions.
I did not add lube or grease, should I have? Probably. It did fix my bouncy needle.
Make sure your nylon gear on the driveshaft side of the cable is in good shape.
If still bouncy its the gauge.
Old Jan 29, 2025 | 06:52 PM
75over77 F100
Thanks for the info.
Hopefully it is just the cable. Even after cleaning it thoroughly a few times the cable was still hard to push through the sheath so I am thinking that may be the issue.
Unfortunately people around my location are acting like jerks so I got held over at work and did not get a chance to work on it today. I will update tomorrow.
Old Jan 29, 2025 | 08:13 PM
TheGreatPumpkin
oh ok your just replacing the core then? I just got a whole new set.
Only thing I though was weird is the old cable had a little nylon needle and the new one was just the square brazed end. Spins just fine just wondering why they did that.
Old Jan 29, 2025 | 08:17 PM
75over77 F100
No I bought a new cable and sheath. Honestly the core in mine now looks good so I am thinking the sheath has a kink in it or internally it is just gummed up.
I think that I will just use a little Vaseline on the new core when I replace it.
Old Jan 29, 2025 | 08:31 PM
TheGreatPumpkin
Hmmm maybe somebody smarter than I knows but I thought plastic and rubbers didn't get along well with vasoline.🤔
Old Jan 30, 2025 | 09:04 AM
tbruz's Avatar
tbruz
Read below for how I solved the bouncing speedo needle issue on my truck.
Tbruz
https://www.ford-trucks.com/forums/1...-resolved.html
Old Jan 30, 2025 | 06:25 PM
75over77 F100
So I had a chance to swap out the speedometer cable and that fixed the bouncing needle issue.
I ended up just leaving the cable as it was as far as lube.
What a difference between the old and new cable set. The old set took a good about of force to remove and replace the cable and with the new set I had to keep the cap on to keep the cable from sliding out.
I do need to change out the gear but am going to wait until I get my new wheels and tires on.
arthall
Jun 14, 2024 06:20 PM
coppertales
Oct 6, 2015 10:49 AM
GJinVA
Oct 17, 2012 05:32 PM
midsouth
Oct 8, 2011 12:33 PM
Nathan
Apr 30, 2001 03:40 PM
