1972 VIN decode
Old Jan 23, 2025 | 12:03 PM
Kansas510's Avatar
Kansas510
3rd Gear
1972 VIN decode
Can anyone help decode the model and engine of my VIN on my 1972 Ford truck? It is 10YKP20773.
Thanks for any help.
Old Jan 23, 2025 | 01:01 PM
Centennial F100's Avatar
Centennial F100
This might help...
https://www.fordification.com/tech/VIN70.htm
Old Jan 23, 2025 | 01:04 PM
Kansas510's Avatar
Kansas510
3rd Gear
Thanks, but the VIN tag under the hood is missing on my truck. All it has is the VIN on the dash & door jam.
Old Jan 23, 2025 | 01:06 PM
Centennial F100
But you have the VIN. Is that not correct, or am I missing something?
There is this, showing locations of the VIN. Does this help?
Finding Your Truck's VIN - FORDification.com
Old Jan 23, 2025 | 01:08 PM
Centennial F100
Would this be any help. Shows locations of VIN.
Old Jan 23, 2025 | 01:15 PM
Kansas510's Avatar
Kansas510
3rd Gear
I have the VIN. The page you suggested is for the VIN Data plate. The data plate shows model, paint, options. That is missing from my truck.
Old Jan 23, 2025 | 02:12 PM
Centennial F100
Your original post asked about the model and engine. From your VIN this, and other information, can be determined from the charts in this link. Decoding Your 1972 Ford Truck VIN - FORDification.com
Is there not an "F" at the beginning of your VIN.
Also, you may want to obtain a Marti report, which based on your VIN provides a lot of information about your truck if you are interested. Marti Auto Works - Marti Report
Old Jan 23, 2025 | 03:20 PM
tcanthonyii's Avatar
tcanthonyii
I will second Centennial. Marti is the best way to do it.
Old Jan 23, 2025 | 06:49 PM
52 Merc's Avatar
52 Merc
I'm not aware of any vin plate under the hood. All there is is the door jamb and door frame plate and decal. I don't remember when they started putting the number in the windshield, but it is in that timeframe so if you have a number there, that's helpful. I'm confused since you say you have the vin number in the door jamb, but since it's on the plate, and you said you don't have the plate, where are you seeing the number at?
The vin breaks down as F100, 360 engine, built in Kansas City, May '72. That's all there is to know there. As the others have mentioned, getting a Marti Report will give you more details about your truck. He also makes replacement plates if you want one and need one.
Old Jan 23, 2025 | 08:56 PM
Centennial F100
52 Merc,
Oddly enough I have the VIN tag under the hood as well, left side. This is not a great picture, but it is the VIN stamped on light gauge plate. It is not laying flat and the factory primer is visible behind. This truck was built in Canada, not sure if it was only certain assembly plants that would have done this.
Old Jan 23, 2025 | 11:23 PM
RichS2659's Avatar
RichS2659
Since 1970, there is the safety certification sticker that listed added info that was on the door data plate. It is located under the door striker on the door jamb. With age, they do become unreadable.
Old Jan 24, 2025 | 07:51 AM
52 Merc's Avatar
52 Merc
Originally Posted by Centennial F100
52 Merc,
Technically it's not a vin plate but what's known as a buck tag. Typically it has codes for options that the assembly line workers need to know to make sure the right parts are installed at the factory. Only some factories used them. I couldn't tell you which truck plants used them or not, but of the 3 plants that built Mustangs back then, only one, Metuchen, NJ, used the buck tag.
1965-66 Buck Tag information
Old Jan 24, 2025 | 08:50 AM
Centennial F100
Thank you. I learned another thing today!
I always wondered why it was just installed with a hex head screw, but that makes sense now.
FordMan1981
Large Truck
Nov 23, 2024 06:16 PM
kkeez
Large Truck
Feb 24, 2024 07:38 PM
xgkrx
20
Jul 10, 2022 05:04 PM
Kjh6
Large Truck
Aug 10, 2021 11:45 PM
fslay
Large Truck
May 24, 2021 03:58 AM
