There isn’t a door tag. The title reads exactly as I posted. It’s a dentside cab, so definitely not a 67.
The only tag I have found is an under hood tag riveted to the area where the hood meets the cowl. It’s a plain strip of aluminum, and not a typical door tag
Any information you have is greatly appreciated. Although this is a dentside cab, do I understand correctly that the floor and firewall panels are from the 67-72 generation?
I can't answer that specifically. The cabs are the same as the pickups for the corresponding years. Fenders are different, sometimes the floors. But doors, glass, roof etc, same as the pickups.
It would not surprise me to find floors and firewalls the same even though the rest of the cab went through a "model change".
Post 5 has the videos and my version. There are more 2 speed links in the Tech Section at the top of this forum.
