Help With Decoding VIN Please...
Old Jul 6, 2022 | 07:38 PM
xgkrx's Avatar
xgkrx
Hello F.T.E.'s,
can someone please help me and decode This VIN ???
VIN: 2FDLF47M4KCA64285
The Owner of The Truck that this is from is telling Me that His Truck is A 1988 F450,,, and I want to be sure that it is OR is not before I purchase it.
Thank You.
Graeme...
Old Jul 6, 2022 | 07:59 PM
Scndsin's Avatar
Scndsin
Have a go with this on site:
https://www.ford-trucks.com/forums/vindecoder.php
Old Jul 6, 2022 | 08:36 PM
xgkrx's Avatar
xgkrx
G' day David,
Thank You for Your reply,,, I appreciate it.
As You suggested,,, I tried this but got a reply saying that The VIN isn't recognised.
Cheers Graeme...
Old Jul 6, 2022 | 08:48 PM
Scndsin's Avatar
Scndsin
That's unfortunate. The 2F alone would make it a 92 there should/would be a T after the F to indicate a truck normally.
Is this Oz manufactured or US?
Old Jul 6, 2022 | 09:06 PM
xgkrx's Avatar
xgkrx
G' day David,
Again,,, Thank You for Your reply and information,,, I do appreciate it.
This Truck is A Left Hand Drive / USA Import.
I have not yet seen it in person,,, and am relying on information sent to Me from The Owner / Seller.
Maybe The "D" is actually A "T",,, and He has read it wrong ???
I will see if I can attach a couple of pics..
Cheers Graeme...
Old Jul 6, 2022 | 10:09 PM
Conanski's Avatar
Conanski
The truck does appear to have 10lug wheels.. which would mean it's heavier than an F350.
Ask the seller to send you a pictue of the certification label on the drivers door pillar.
Old Jul 6, 2022 | 10:14 PM
xgkrx's Avatar
xgkrx
G' day Paul,
Thank You for this advice,,, I appreciate it.
As The Truck has "Wheel Covers" on it then I will check with The Seller if it is 8 or 10 Lug.
Are there any other "Easy To See" things that tell The Differences between An F350 and An F450 ???
Cheers Graeme...
Old Jul 6, 2022 | 10:15 PM
xgkrx's Avatar
xgkrx
G' day Paul,
Cheers Graeme...
Old Jul 6, 2022 | 10:18 PM
Scndsin's Avatar
Scndsin
It should have a data sticker on the drivers door frame, something like this that will answer many questions:
(Edit, Paul beat me to it.)
Old Jul 6, 2022 | 10:20 PM
Conanski's Avatar
Conanski
Yeah I know what you mean about the wheel covers.. they can be decieving, my E250 has 7-lug wheel covers over 8-lug wheels.
See the additional suggestion in my original post above.
Old Jul 6, 2022 | 10:38 PM
wwhite's Avatar
wwhite
2FD World Manufacturer Identifier
L Brake Type and GVWR Class
F47 Line, Series, Body Type
M Engine Type
4 Check Digit
K Model Year
C Assembly Plant
A64285 - Production Sequence Number
2FD
- Canada Ford Incomplete Vehicle
L
– 14,001-16,000 lbs.
F47
- F-Series F450 Cab and Chassis
M
- Diesel 446ci 7.3L
K
- 1989
C
- Ontario Truck (Oakville, Ontario Canada)
Someone needs to create a correct and accurate VIN decoder, doing it manually always works.
Now you need a picture to verify VIN on vehicle.
xgkrx's Avatar
xgkrx
G' day Paul,
do ALL F450's have 10 Lug ???
Cheers Graeme...
Old Jul 6, 2022 | 10:42 PM
xgkrx's Avatar
xgkrx
G' day WWHITE,
Thank You for Your reply,,, that's Absolutely Fabulous,,, Thank You.
Might You know what The GCM would be for This Truck i.e. What Max Weight 5th Wheel Trailer Could It Haul ???
Cheers Graeme...
Old Jul 8, 2022 | 05:11 AM
AuroraGirl's Avatar
AuroraGirl
M Engine Type
4 Check Digit
K Model Year
C Assembly Plant
2FD
L
F47
M
- Diesel 446ci 7.3L
K
- 1989
C
I suspect it being an incomplete vehicle is part of the problem. Those websites maybe looked at didnt have VINs that are less common. For example, a lot of car VIN sites can never figure out my Yamaha's VIN. Even though its a standard vin just like a vehicle(1987 Moto-4 with a 225cc lol)
Old Jul 8, 2022 | 05:16 AM
AuroraGirl's Avatar
AuroraGirl
Nevermind, I found 2 websites that both allowed it to show results. NHTSA helped here, even tho it was made in canada and probably never has come here. Its likely because canada signed on to a lot of the NHTSA / EPA regulatory things as far as vehicles go
