OTA software update yesterday
Old Jan 19, 2025 | 07:10 PM
RadRick's Avatar
RadRick
Yesterday a message displayed on the center screen that a software update was available. When I got home I went to the software update tab and hit install. This morning I had a message on my FordPass app titled, Enhance Window Detection System - Your vehicle’s driver door module has been updated to reduce false bounce back alerts when closing your windows. Experience smoother and more dependable window operation with this enhancement. Software updates are designed to help make your vehicle better over time. DDM-24.19.3.
I’ve never had a problem with my windows, nor have I seen this message.
I drove my truck again today and noticed my engine oil temperature gauge had been replaced with the pressure gauge. This makes me wonder if this update also did something with the oil pressure…
2024 F-350 Lariat Ultimate 7.3
Last edited by RadRick; Jan 19, 2025 at 07:11 PM. Reason: Forgot to add vehicle details
Old Jan 19, 2025 | 07:16 PM
Fox-BLUE1's Avatar
Fox-BLUE1
There was a recent thread about issues with bounce back.
https://www.ford-trucks.com/forums/1...unce-back.html
Hopefully this will fix it.
Old Jan 19, 2025 | 07:18 PM
Shepherd of Fur's Avatar
Shepherd of Fur
Trailering
When it updates I've noticed it likes to reset the custom gauges. I have had a couple roll up bounce back when closing the windows in the heated garage hopefully it fixes it.
Old Jan 19, 2025 | 07:57 PM
RadRick's Avatar
RadRick
Thanks guys, I hadn’t heard about any issues with the windows. Makes sense an update may return some settings to default.
Old Jan 19, 2025 | 09:19 PM
powerboatr's Avatar
powerboatr
bingo. Otas do tend to reset my view and changes you made in menu section
Old Jan 20, 2025 | 01:16 PM
acdii's Avatar
acdii
Anytime the modules reset, it will set the gauges to default. Everytime I used Forscan I had to go back and adjust them.
Old Jan 21, 2025 | 07:33 AM
kylant's Avatar
kylant
true about resets. however, i don't think the oil gauge ever had a pressure reading.
is it reading a number?
Old Jan 21, 2025 | 04:16 PM
RadRick's Avatar
RadRick
kylant, I had changed the pressure gauge to the oil temperature gauge, swapped the gauge position, and added the numerical temperature readouts, so I had engine coolant temperature, engine oil temperature, and transmission fluid temperature. The update changed the oil temperature gauge back to the oil pressure indicator, which has no numerical readout, so it caught my eye. The update did not put the gauges back in the original order. This is the third OTA update as far as I’m aware. The first two did not affect any of my settings.
Old Jan 21, 2025 | 05:27 PM
kylant's Avatar
kylant
it would be nice if the oil pressure gauge had a number
Old Jan 21, 2025 | 10:06 PM
Habemus Quattro's Avatar
Habemus Quattro
Unless Ford actually changed something for the better (doubtful), the oil pressure sensor that drives the gauge is actually just a switch. It closes at a certain pressure and that’s it. My 2017 had a wiring fault from the factory where one of the pins on that connector was faulty so I would randomly get low pressure warnings. That’s how I learned it’s not a pressure transducer at all. Just a silly switch. My guess is Ford is still using that part.
Old Jan 22, 2025 | 01:13 PM
acdii's Avatar
acdii
Mine got one the other day, thankfully it was for Sync so the gauges remained as set. Fordpass also showed and explained what the update was. Now that was a nice change.
StoneyMeadowMaple
Jan 27, 2024 07:46 PM
Keith Griffin
May 24, 2023 01:05 PM
networkit
Nov 7, 2020 12:13 AM
montauk1
Jun 13, 2016 06:42 PM
MIKES 68 F100
Aug 4, 2015 02:53 PM
